1992 pickup speedometer electric or cable driven?
Old Mar 7, 2011 | 08:01 AM
matt92yota's Avatar
i picked up an sr5 gauge cluster from the junkyard this past weekend and it is cable driven, but i was wondering if my 1992 pickup was either electric or cable before i start taking my dash apart.
Old Mar 7, 2011 | 08:14 AM
Birdbrain's Avatar
I am fairly confident that its an electronic... I think 92-94 was the years for the electronic speedo sensor.
Old Mar 7, 2011 | 08:18 AM
tj884Rdlx's Avatar
if it's a 22RE manual trans, it should be a cable. you should be able to see it coming through the firewall.
rockauto.com shows it for $8.52
http://www.rockauto.com/catalog/moreinfo.php?pk=15259
Old Mar 7, 2011 | 08:19 AM
xxxtreme22r's Avatar
or stick your head under the truck and look for it on the trans.
Old Mar 7, 2011 | 08:20 AM
Birdbrain's Avatar
You know... Thats not a bad idea actually...
Old Mar 7, 2011 | 08:21 AM
Birdbrain's Avatar
To the OP if its mechanical, it will have a round plug on the back, passenger side of the tranny.
if its electric it will have a black, rectangular plug that you can undo like any other plug on a wiring harness.
Old Mar 7, 2011 | 08:22 AM
matt92yota's Avatar
i'll have to go look once i get out of class lol thanks guys
Old Mar 7, 2011 | 08:23 AM
blake.nemitz's Avatar
mine has an electric speedo sensor and a motor that drives the speedo CABLE under the dash, its a 95
Old Mar 7, 2011 | 08:36 AM
WHAHAHAJR's Avatar
My 92 22re manual is electric...
Old Oct 8, 2011 | 02:58 PM
JeredSmith's Avatar
Speedo cable issues
I have a 1988 4runner that was an automatic with a Speedo cable, but recently swapped it with a 5spd from a 1994. The 94 is set up for an electronic speed sensor. Is there any year when they were interchangeable? Can I still set up a Speedo cable instead of the electronic sensor?
Old Oct 8, 2011 | 05:45 PM
TylerH's Avatar
Great questions. I searched and got the same answer, i guess ill have to check when im flushing the tranny this weekend.
Old Oct 8, 2011 | 11:37 PM
john4wd's Avatar
The 1992 2wd 22R-E 5-speed truck had an electric speedo, It was wreaked and I bought the full gauge cluster for 20 bucks and stuck it in my 93 4wd truck after adjusting the odometer. How to on that is on my build thread...
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 6, 2015 07:45 PM
wilbertd
Jul 6, 2015 07:39 AM
