92 reg Cab 4x4 pickup belt squeel
Old Mar 9, 2011 | 08:39 PM
cred92's Avatar
okay im really new to the forum.
My 92 Regular cab dlx pickup with the 22re and 5speed, it squeels really bad on start up and sometimes just going down the road starts squeeling like a witch. What should i check pulleys, belts what?
Old Mar 9, 2011 | 08:47 PM
atari56's Avatar
I'm having the same problem, only squeals on start up though, I thought it was water pump at first, wasn't. I checked and tightened all belts (some were loose) but three days later it started again. Dropping truck off at trusted mechanic this Saturday (busy week coming up, no time to tear into things), will report what final diagnosis is.
Old Mar 10, 2011 | 04:51 AM
cred92's Avatar
Yea let me know what your problem is, im thinking about replacing all my belts. Im just hoping its not harmonic balancer pulley r water pump, cause that would kill my tire budget right now 33 12.50 15 bfg at i plan to put two nankang mudstar they look just like a maxis buckshot. only need two for now two bfg have plenty of tread to last a couple months.
Old Mar 10, 2011 | 03:09 PM
swampfox's Avatar
You can clean them with warm water and soap if they are not worn to bad ,it might stop the slipping and squealing.
Old Mar 10, 2011 | 03:27 PM
toyota4x4907's Avatar
How much are belts? $10-$12 a piece? And you have two if you dont have A/C. Thats cheap. And easy to replace. I've had the power steering idler pulley on my '93 22re explode while driving. That was not much fun. While replacing the belts, check the pulleys for excessive wobble.
Heck, belt(s) could be too loose or too tight...
Old Mar 13, 2011 | 09:20 AM
cred92's Avatar
Sooo i had some free time saturday and was fiddling around with my yoyo, checked the belts i only see one belt tensioner bolt at the very bottom of the motor a lil bracket that looks like if you tighten it it tightens the belts. How tight should the belts be? that looks like it only tightens one belt i cant remember which one, and the belts have been replaced before i got it with gates thinking about getting some toyota belts and seeing if that fixes it. this is the 22re fi if i hadnt mentioned
Old Mar 14, 2011 | 09:00 PM
atari56's Avatar
Turns out my water pumP belt came loose again somehow, they tightened it back up for me at not cost.
Sorry for double post, stupid iphone
Old Mar 14, 2011 | 09:01 PM
atari56's Avatar
Turns out my water pumP belt came loose again somehow, they tightened it back up for me at not cost. Good luck on figuring out your squeal. If you have the time and the $$$, replace all the belts and devote a Saturday to it.
Old Mar 14, 2011 | 09:03 PM
peow130's Avatar
Check your alternator belt.
Mine made this sound and it turned out my alt was loose.
DjShiznit
Jul 5, 2015 11:51 PM
Regency
Jul 5, 2015 08:16 PM
Valvoman
Jun 28, 2015 02:45 PM
wagigknp
Jun 24, 2015 12:02 PM
wslytoy
Aug 25, 2002 06:04 PM
