power chip
Old Mar 13, 2011 | 11:58 AM
knickerbocker's Avatar
power chip
i was wondering if anyone has tried using a power chip from g-force co.they`re a legit co.in orange county california.i was thinking of getting one,it interfaces with the e.c.u.they make one for my `86 4x4.your suppose to get more power by way of advancing the timing at higher speeds and optimizing fuel/air ratios.please chime in with your experience or thoughts.
Old Mar 13, 2011 | 12:06 PM
GranVille-4crawler's Avatar
sounds like the ol' resistor chip that tricks your ecu into thinking your getting colder air so it leans your fuel mix out... had one on my '99 maxima. I call them "placebo chips" you might think you gained "up to 20 hp" like the ad says. but not really
edit: what motor is this for?
Old Mar 13, 2011 | 12:07 PM
Flash319's Avatar
Don't waste your money. All electronic fuel injection systems "advance timing at higher RPM's and optimize air/fuel ratios". Unless you have changed some mechanical aspect of the engine then you will see no difference except a lighter wallet.
Old Mar 13, 2011 | 01:51 PM
22re thanks guys
Old Mar 13, 2011 | 02:35 PM
peow130's Avatar
better off buying a header.
money well spent right there.
Old Mar 13, 2011 | 03:11 PM
xxxtreme22r's Avatar
only "chip" manufactures I trust are: JET, Bully Dog, Jim Conforti, and DINAN. None of which make a chip for 22re.
Old Mar 13, 2011 | 04:02 PM
corax's Avatar
scam - you can build your own "chip" like this for $3 at radioshack
Old Mar 13, 2011 | 04:14 PM
shaeff's Avatar
Except for the JET ecu scam for MKIII Supras, what a crock of poop that was proven to be.
Old Mar 13, 2011 | 04:54 PM
ProjectMcFly's Avatar
You could always add a piggyback ECU controller (something like an Apex'i SAFC) if you wanted to play around. Add a wideband O2 sensor with datalogging and do a fuel pulls. Remove or add fuel where you're running rich/lean.
Realistically, you're not going to gain much from it, but it might be fun to play around with.
chukarhunt
Dec 8, 2019 11:39 AM
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
