- White plastic screw on 22re tb?
- Noise in 4WD only
- IFS axle shaft
- Two-tone spray paint on 2nd Gen 4Runner?
- Head gasket changeout ?
- GORGEOUS CUSTOM LIFTED 95 4Runner in SO-CAL Forest Green....eBay
- Steering tugging to one side, with screech
- Is it worth it? 2" or 4" susp
- Front Differentials?
- Cams out of a 92 Camry 3vz
- 4wd dash light on whith key?
- 3.0 V6 Head/headers swap
- whose 4runner is this?
- 86 passenger window replacement question
- Wiper help
- bad vibrations...
- Deceleration Sensor Placement Direction?
- Rev Limiter????
- insurance went up because of age of the truck.
- Time has come do to something with the 91
- Rear Brake Issues
- Dual front shocks
- Oxygen Sensor Question
- List any mods for 86-95 here
- body swap ?'s
- Tie rods?
- Looking to buy a 95 4Runner
- Clutch to buy or not to buy
- do i have abs?
- center link got fixed today
- cant get a high brakepedal
- license plate light wiring
- o/d codes 62 and 63
- head/block resurfacing recommendations?
- ARB bumper
- Steering relay rod replacement safety recall notice
- 22re running rough
- E-locker part number
- Clutch opinions for 90 4runner
- Front brakes
- Which 3.0 do I have? (not stock)
- How to fix the passenger seat?
- Which coils are best on a 2nd gen?
- Second Gen. throttle body problems.
- heater coil pack
- Won't start, no CEL. Bad ECU or connection?
- Header vs stock manifold
- Door Buzzer location
- Knock Sensor issues...out of ideas
- Sputter, cough... Timing Belt?
- getting reemed at my local dealer(parts)
- 93 Runner rear window has a mind of it's own!!!!
- Steering stabilizer
- EGR noise *Searched*
- 95 sr5 v-6 4x4 5spd shifter popping out of gear
- Rattling Shifter...HELP!
- Need some help designing my exhaust system for the 3.0
- Wierdest thing - Engine dies
- Best SNOWBOARD rack for 2nd Gen. 4runner?
- VIN Identification
- Who wants a metal head gasket for their 3.0?
- Is my speedometer correct?
- 1993 Runner Overheating, Need info on Changing the Thermostat
- Headwork in AZ
- New, used or rebuilt transmission?
- Another problem
- O/D problems? (90 4Runner)
- Pic's of CB placement?
- clicking sound in engine
- Heater AC Controls Hilux/Surf
- Differences between corner lights 89-91? (pics)
- rear end bolt stripped
- rotor removal question
- 4WD Problems
- Broke my 1st cv shaft. Now i need help.
- 95 'runner bouncing in front--help!
- ***22re fuel filter location***
- 94 toyo not firing,PLEASE HELP?
- 22RE to 3vze Swap?
- screaching 4runner in wet weather
- Alternator wiring help!
- Just finished my first timing belt/WP change on my 3.0
- 4" superlift for regular cab
- Ford 4.0L SOHC --> 2nd Gen Runner?
- converting 87 2wd to 5VZFE, questions
- Bad idle when warm!
- please help asap, truck wiring messed up or something
- A lesson learned (pics)
- 89 Chevy spring swap Question & Request.
- Severe stumbling/hesitation and stalling (Longish post)
- Head Gasket gone, how much longer can I drive
- Anyone ever use megasquirt in a 3.0
- Ruff Idle When Cold
- 3.0 camshaft sprocket bolts?
- to sell or not to sell
- How much oil do you go through?
- Transfer case ?
- O2 sensor code on 3.0 with new a sensor
- Xtra cab or regular cab frame
- Rear Springs #
- 93 4X4 Truck Fuel Filter
- 98 Tacoma Rims on 87
- 87 SR5 4runner maplight bulb replacement?
- what is the ultimate backspacing for R15 with a 32" AT tire
- Anyone make a factory a/c kit for my 94 p/u??
- EGR removal on 3.0
- BJ spacers/HD coils - shocks to match
- A340H modification for 3.4 SWAP
- New bumper, with after market blinkers having problems
- 3VZE ignition timing revisited
- rear windows problem
- pulling the Intake MAnifold
- Front end rebuild ???
- 3VZE - Finished head job, turned key and...
- toyboxfab.com?
- window trim piece?
- Power window relay
- Help me find interior parts
- 1995 4runnner exhaust question...
- pics of trucks with black steelies
- Lift Height Measurements?
- I cant find the flasher relay on my 95 4runner ahhhhh!
- Body parts
- 22re idle is crazy
- starts, runs, but then dies
- SFoam/Injectors
- Speedometer has A.D.D.
- engine start up after rolling truck
- 1991 4runner partition wall behind the rear seats
- rebuilding an A340H tranny
- Hanging up my Hat
- Clutch Slipping
- exhaust running to lean. wont pass smog
- Problem while replacing brake pads
- Wont Start!?!?!? (seems to be everyones problem)
- 22re is toast!
- Headgasket- Toyota or Fel Pro?
- Downey idler gusset fits spicer idler arms.
- 3.0 Valve Adjust
- 3VZE Timing Question
- 87 22R CA model question
- speedo cable ?? cel 42 and od code 42
- 89 V6 Power steering
- Any 2nd gen 4Runners running a diff drop?
- Any one have a 2nd gen with a 4" ProComp lift?
- No spark
- studs or bolts for headers
- 3vze rebuild update (pics)
- 91 toyota 4x4 clicking well broke...........
- Frame Bent (pics)
- Is this a good camshaft?
- e-locker for 2nd generation
- Keystone Steel Wheels?
- New Master cylinder quality
- Bad Motor
- Reverse light switch location
- Random Engine Clatter
- Anyway to check headgasket?
- Mileage
- Timing chain replacement various noises
- Remove catalytic converter for more power??
- Oil pump is toast and metal is everywhere... where do I go from here?
- Thread size for oil press sender in 22re
- E-locker question
- Help me sell the M/T to my chick...
- 3rd Gen toy truck parts for sale.
- Lifting a 91 2wd
- what gears do I need
- Clutch Pressure Line
- Brake problems after a few minutes
- 91 4Runner: Bad Ground/tail, license plate, driving, and dash lights out
- my ADD went bad?
- What could be causing it to overheat?!
- Screwy idle
- AFM test
- swaping rear ends, do i have to do the front too?
- Gas Gauge Stuck On FULL???
- ABS Light, Brakes Fine???
- 2nd gear hard to shift.....synchros?
- Swap rear end from 4 runner to pick up
- Downey springs
- highway rpm 91 22re 5sp 2wd
- running rough during acceleration
- Marlin Rear bumper installed finally with pics
- *I've Searched* - Optima 34R Needed, correct?
- 22Re feeels like it has turbo lag?
- what is the stock ride height on an 88 4x4 pickup?
- cleanest engine bays
- tow hooks??
- transmission problem. accelerate car dont want to move.
- New headlights install
- 5.29's too low?
- 4runner shop manual
- Automatic transmission dipstick 3vz
- Lookin at a 3.4 motor for a swap and need some advice
- Electrical Problems 93 forerunner
- Need idea for Hi-Lift mount
- Trans/Tranny being pushed forward when hitting bumps..
- EGR problems on a 94 22RE
- Need spark plug numbers for '92 4R
- 22RE Problems
- I have $100 what muffler do you suggest?
- tacoma bed swap???
- 89 3.0 Problems
- spare tire
- Tacoma TRD fender flares
- Nit Picky Lift details
- Swap Ideas Opinions needed.
- Universal Flares on 2nd Gen 4run??
- Diagnostic scanner for 1st gen?
- Disconnect automatic locks
- Hard to shift into first gear from nuetral
- Dilemma-- 4.3 or 22r-e (long)
- 95 4rnr 22re spark plugs way light color
- Allignment?
- 86 4runner clutch slave cylinder gone out?
- Tps question
- 3.0 quitting at startup
- Performance intake parts for the 3.0
- Another 3.0 Bites the dust. Blown Head Gasket.
- '94 22R-E - Large screw on EFI intake
- 95 4runner; problem getting started
- Rear window problem(searched)
- adjusting emergency brake: SEARCHED
- Power steering pulsing on 2nd gen 4Runner
- Burning rubber
- Clutch Blues
- tach install help
- 86 22re Pickup Not running after flood
- Question About E.C.U. Swap
- Getting codes 3VZ
- How much rear lift do you have on your 1990-1995 4Runner?
- 89 4 Runner: Engine Year Compatability ??
- HELP Loose Fan Pulley!
- cold idle speed adjustment 22re
- 95 manual transmission shifter leak?
- Sliders for 2nd gen - weight, where to buy
- What causes this build up? (Big pics) 22RE Sludge?
- Real quick tire question
- u bolt size for 1st gen, lift questions
- aftermarket sun roofs and speaker questions in 1988 Xcab!
- 4wd powersteering interchangable with 2wd truck
- 94 Runner 4WD Low not engaging?
- Fuel Gauge Help 22RE
- Options for roof rack for 89 4runner?
- white face gauge install
- 3.0 spark plugs
- Matching a Superlift?
- Rear brake drag
