How much oil do you go through?
So between oil changes, how much oil does it take to keep the dip-stick at full on your 3.0?
Right now, my '94 pickup is chugging it back at a rate of 1.5L per oil change. It's got about 215,000Km on it. Is this normal?
Sounds about the same as the 93 I had, 1.5 - 2L in between changes. Mine had 220,000km on it.
Now that I'm driving an 01 I don't use any
I go through about .5 of a litre between oil changes around every 5000km. If I am doing a lot of heavy towing I will use about 1 litre. My motor has 386,000 kms on it
the camry is about .5 litre with the V6 and 378,000 kms on it
I don,t bother topping up , only go through .5 a litre/5000km or so, and thats with a leaky distributor. I use 5W30 toyota oil & filters . Its has 80,000kms (freeway miles) on a 2 year old dealer HG recall rebuild. (222,000kms on vehicle)
Originally Posted by Corey
Not a drop, and that is twice now going around 8K or better with my Amsoil.
Even with my engine running on only 5 pistons, it still does not use a drop of oil.
Have 180K on my original 3.0 and run Amsoil series 2000 0W30 syn. I have run Amsoil since it was new (switched at 30K to allow the motor to break in) and change it once a year and works out to about 10K miles. Also have the dual remote bypass filter system.
Originally Posted by RustBucket
Me too, about a quart per fillup.
"Fill up the oil, top off the gas!"
(that's what you get when you put a brand new head on top of an tired old block!!)
I didn't think of it like that, but your right.
Glad to know I'm not the only one!!!!!!
I'm hoping next year to have it rebuilt.
