Screwy idle
Old Jan 7, 2006 | 03:43 PM
TinyTruck's Avatar
Screwy idle
was having a problem last night with the idle on my 1994 4-runner w./ 22re.
The usual idle on this pig is about 5-700rpms. While sitting in my friends driveway idling away with the pedals tottaly clear the idle jumps to about 3000rpms, then drops down to about 1700-2200rpms where it fluctuates from that range to about 3300rpms. At this point I stab the gas to bring it to about 6000rpms, when I let off it dropped down to about 1000rpms where it stayed for a second and then jumped back up to the 1700-2200rpm range again where it stays for about 30seconds. After all of the above it settled down to the 250-500rpm mark (acceptable?).
The whole time it sounded as if it had a lumpy cam in it
Old Jan 7, 2006 | 06:58 PM
91_4x4runner's Avatar
Was it cold outside? 3300 seems quite high but the engine may have been adjusting to operating temperature?
Old Jan 7, 2006 | 06:59 PM
terryjmatthew's Avatar
6000 rpm's? Do that a few more times and it should fix itself!
Old Jan 8, 2006 | 05:56 AM
TinyTruck's Avatar
it was about 30deg outside but the thing had been drivfen for about 10min and was already at warm idle
TinyTruck's Avatar
6 grand is 500rpms below redline
Old Jan 8, 2006 | 07:43 AM
celica's Avatar
Try cleaning your throttle body really well. Sounds like it is gummed up. I would also run some good fuel injector cleaner through it. I usually do a double dose when I do mine.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
