Matching a Superlift?
Old Jan 1, 2006 | 10:30 AM
Bill's Avatar
I found a guy locally who's selling a 4" superlift, basically everything on the front end(lift, downey torsion bars, shocks and a bumper).
I'm trying to figure out the best way to match the 4~" lift, in the rear of my '92 runner I'm on the stock coils still. So I was thinking if I crank the t-bars down a little bit, I could lower the front end to about a 3" lift, then put 2" coils and a 1" spacer in the rear.
Anyone have any other ideas?
Old Jan 1, 2006 | 11:37 AM
hill's Avatar
bill you can get the downey HD coils and a 2" spacer to match 4" of lift in the rear and go with longer springs...
go for BJ spacers up front
Old Jan 1, 2006 | 12:17 PM
AW1090's Avatar
I don't think you can lower the front any lower than the 4", but you can raise it a bit....you could always crank the tbars a bit and run cruiser coils...
Old Jan 1, 2006 | 12:22 PM
Bill's Avatar
I'm not totally sure what I'm going to do yet. Either go with a 4" superlift "type" lift, or go with a 2" lift using BJ spacers, OME t-bars, and 2" OME coils(going through strap22).
I know I want to be able to clear 33x12.5's. Don't know if/when I'd get a set, but I'm trying to plan ahead.
Old Jan 1, 2006 | 02:13 PM
Flamedx4's Avatar
Is the Superlift kit really a 4" lift? Most are a 3" lift and then you crank the Tbars to get the extra inch.
Old Jan 1, 2006 | 02:41 PM
rockota's Avatar
When I installed the SL kit on my ex-wife's 94 4Runner (25mm torsions), I got ~6" of lift. I had to reindex the torsions to level the front w/ the 4" rear.
Personally, I think there are two options.
1 - buy the rear kit from SL
2 - convert to leafs.
I don't like the mix-n-match approach. And there's NO WAY that you'll lower the SL kit to 3", as far as I can tell.
Old Jan 1, 2006 | 05:31 PM
tc's Avatar
tc
I would go with cruiser coils instead of spacers. If you're going to have all that lift - why not get travel out of all of it?
LittleUgly
15
Jan 2, 2020 01:30 PM
stanz
Oct 30, 2015 10:33 AM
ktm192k
Sep 24, 2015 03:36 PM
BimmerSage
Sep 17, 2015 11:48 PM
BimmerSage
New York
Sep 17, 2015 05:21 PM
