Trans/Tranny being pushed forward when hitting bumps..
Old Jan 6, 2006 | 08:50 AM
91Toyota4x4's Avatar
OK here's the deal. 3.0 V6 Ext Cab pickup.
When I hit bumps something is pushing my transmission and transfer and I guess motor forward. I can watch my shifters move forward and back in phase with my rear end compressing and extending. I had a bad UJoint at the diff and replaced that and greased my splines but it is still doing it. The truck also shakes at 40-45mph, don't know if it's related though.
Has anyone else had a problem similar to this??
Old Jan 6, 2006 | 11:50 AM
Marc's Avatar
My auto shifter moves back and forth about a 1/2" over bumps.
Never really worried about it. Maybe I should.
Old Jan 6, 2006 | 11:53 AM
Flamedx4's Avatar
It's normal for the shifter to move left and right with engine torque, and it does shake some. But what you're describing sounds like maybe you filled the rear driveshaft slip joint full of grease and it can't compress. Try removing the zerk and drive it and see if grease comes out of the zerk hole. You might need to separate the driveshaft and clean it out.
Old Jan 6, 2006 | 12:43 PM
snap-on's Avatar
I was under the impression that that was impossible as the grease would be forced past the splines on compression. there is a gap there afterall...
Old Jan 6, 2006 | 01:07 PM
It was doing it before and after the grease.
Old Jan 6, 2006 | 04:03 PM
Flamedx4's Avatar
Not impossible at all, you are not supposed to fill it up. Sure there is a bit of a gap, but it's small. It has to be small or the thing would wobble... The grease won't just come squirting out of there easily if it were overfilled. If you look at the slip joint on your driveshaft you can see how much it moves - mine moves a good 2"!
boguspiano
Dec 17, 2015 02:51 AM
I8URSVT
Sep 3, 2015 11:42 AM
skypilot
Aug 25, 2015 01:09 PM
Duppie007
Aug 20, 2015 04:39 AM
norcal98
Aug 10, 2015 06:20 AM
