3.0 spark plugs
Old Jan 1, 2006 | 05:16 PM
Kyle95sr5's Avatar
3.0 spark plugs
im doin some maintanence on my 4runner with the 3.0 and i just can't figure out how to get my spark plugs out. i got the drivers side, you just take off the air tube but the passenger side is all jammed up in there. do you take off the plenum or go in through the fender? just dont see how you could do it without something being taken off. thanks for the help.
-Kyle
Old Jan 1, 2006 | 05:18 PM
gohawks's Avatar
I didn't have to take anything off for either side, just used an extension.
Old Jan 1, 2006 | 05:24 PM
Kyle95sr5's Avatar
how do you get all in there i got my hand in there to change the wires but dont see how u can get in there with an extension and see what ur doing. has anyone tried to go in through the fender?
Old Jan 1, 2006 | 05:25 PM
freshman's Avatar
it helps too if you want to remove the battery from its place as you are doing the passenger side. I used extension when i replaced mine but its nice to check if there's dirt going with the sparkplug as you put it in place and by removing the battery, it helps to provide a working space.
Likewise, you can clean the battery posts too thouroughly when its out there.
Old Jan 1, 2006 | 06:02 PM
Paul H.'s Avatar
I have never had any problem getting the passenger side plugs out. They were easy compared to the drivers side.
Old Jan 1, 2006 | 06:04 PM
AgRunner06's Avatar
You don't have to remove anything. The 1 and 3 plug (front and middle) are easy. All you need is a longer extension. The 5 plug is a little more trickey. You have to pretty much do it by feel. I have small hands so it wasn't too bad for me. Just be careful threading it in there. Make sure you use anti-seize and it should thread it fairly easily. I can't remember if I put the new plug in the extension and then started threading it or if I started it by hand.
It can be done. It just takes some patience.
Old Jan 1, 2006 | 06:34 PM
Blair's Avatar
Use a sparkplug socket that has the little rubber grommet inside to hold the plug on insertion, with about 18" of extension, and a U-joint swivel on one end. I just did mine after a seafoam treatment. Man, I hate doing the driver side. This time I tore up the intake tube, taking it off. It was getting a little stiff anyway.
Old Jan 1, 2006 | 06:39 PM
93ToyKid's Avatar
My pass. side back plug hole stripped out when I put my new plug in. Actually, it may not be stripped, but it only goes in half way before it stops turning. May want to run a thread chaser through them before you put the new plugs in to clean the gunk out. Sure wish I would have...
Old Jan 1, 2006 | 06:56 PM
Kyle95sr5's Avatar
ight, maybe i was just missing somethin since everyone seems to be doin them fine. ill try again tomorrow. thanks for the help guys.
-Kyle
man that sucks about ur threads. i was readin about that and would hate for that to happen to me. what do you do if it is stripped. do you gotta take the head off and all that good stuff?
Old Jan 2, 2006 | 07:40 AM
Sequoia'd's Avatar
Passenger side #5 comes out real easy with a 24" extension and a u-joint. 24" best tool I ever bought for changin that last plug. Cut time by 3/4!! Driver side #2 is tight since dist. is so close on '91 V6. Just got to work around all the plumbing... gets easier with practice. Good wrenchin'
Old Jan 2, 2006 | 07:47 AM
mt_goat's Avatar
Yeah, extension and u-joint. Be carefull going back in so you don't cross thread.
Old Jan 2, 2006 | 07:52 AM
UKMyers's Avatar
I bought a T-handled spark plug wrench that has two swivel joints in it from AutoZone for like $8 it works awesome.
Old Jan 13, 2007 | 05:47 PM
slosurfer's Avatar
I used the rubber hose trick when rethreading spark plugs. It is tight enough to turn the plug but if it crossthreads the hose will just spin on the sparkplug. I haven't changed the sparkplugs on the 4runner yet, but it looks easy compared to the 8 plugs that I just changed on my '96 B2300.
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
