rotor removal question
Old Jan 15, 2006 | 01:11 PM
i_rifiyou's Avatar
hello yotatech.
i have a 2nd gen 4runner, i and in the middle of changing the rotor and i can't get it off. i'm not having much luck with the search engine, can someone post a link with some pictures since i dont know all that part names.
thanks yotatech
Old Jan 15, 2006 | 01:18 PM
VA_Yotaman's Avatar
Brake rotor, or rotor under distributor cap?
Sorry no pics.
Distributor rotor should just pull off. It is a long, almost pie-shaped piece of plastic with an electrical contact at the end. When you pull the distributor cap off, it is right there.
As for the brake rotor, I have never had mine off. One most vehicles, you just pull the brake caliper off, and the rotor should pull of easily.
Old Jan 15, 2006 | 01:22 PM
VA_Yotaman's Avatar
Found a pic of distributor rotor. This should be yours if it is the V6.
Old Jan 15, 2006 | 01:23 PM
i_rifiyou's Avatar
sorry about that, it's the brake rotor
Old Jan 15, 2006 | 02:21 PM
i_rifiyou's Avatar
ahhhh found it.....http://www.4x4wire.com/toyota/mainte..._end/teardown/
88sasturbotoy
Jan 30, 2026 01:57 PM
kazuya2416
Apr 5, 2024 02:17 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
msane99
Jul 11, 2015 08:08 PM
