Second Gen. throttle body problems.
Old Jan 17, 2006 | 07:53 AM
hokiruu's Avatar
My Runner has been idling a bit high (up to 1800rpm) and not just because it's cold and warming up. Somewhat erratic too. I wasn't sure what it was and I usually do my own work, but I'm too busy lately. So reluctantly I took it down to my local toyota specialist. After checking it out they told me the throttle body assembly is sticking. they have a used one they offered to install for $275. They also said a new one costs $800, which sounds a little inflated to me but havn't looked into it carefully yet. I have heard of people remedying this with sprays, at least for while.
What do you think? My runner only has 89,000 miles. I am surprised my TB would be so jacked it needs to be replaced. Do you think I should try cleaning it? Should I just have them put it on, or look for one from Napa or something to put on this weekend myself?
While I am on the subject, is there any affordable and easy bolt-on upgrade, maybe larger bore TB from another engine I could do while I am addressing this?
Old Jan 17, 2006 | 08:15 AM
callmej75's Avatar
Larger bore TB isn't gonna help much on a stock engine unless you had the heads and intake ported and all that good stuff. If it was me I would take the TB off, buy some TB cleaner, take the throttle position sensor off, and clean the butterflies and inside where the sensor goes. Thats all it needs. You will need a multimeter to set the TPS with. If it isn't set properly then it will not run right.
Average cost: $5 Throttle body cleaner
$20-30 Multimeter
Old Jan 17, 2006 | 08:37 AM
hokiruu's Avatar
thanks callmej. i think i'll just pick my runner up today, pay them for diagnosing it and try that. worth a try, right? if it works, i'll never send anyone to that shop.
Old Jan 17, 2006 | 08:41 AM
callmej75's Avatar
No prob...mine sometimes sticks and I take the TB off and spray it down and it fixes it right up. Just remember to get that TPS off because the chemicals in the TB cleaner can screw it up. Or you could take it to a shop that has a TPS scan tool and they can set it for you for $20-$30. Still beats over $200! Good luck..
Old Jan 17, 2006 | 10:37 AM
hokiruu's Avatar
got the vehicle back without spending a cent. i'll try that this week.
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
mtc1105
Aug 4, 2015 08:06 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
