- clutch leaks
- heat
- 91 3vz poor economy
- Fuel Pump Woes
- Misfire under load?? Fuel pressure regulator?
- 1st gen 4Runner wood paneling on interior
- '88 4Runner: can't bleed a front brake
- '88 4Runner Speedometer
- need trailer hitch
- 1986 Pickup Tailgate Logo replacement??
- Thread Pitch?
- Whirring sound from trans/clutch system?
- Rear seats for a first gen?
- just bought 86 xtra cab!
- W56 Reverse Restrict Pin alignment?
- Towing limit questions
- 86 4 runner starting problem.
- Minnesota winter has arrived! Couple questions....
- 92 4runner a/c breakdown
- Tachometer not working?
- Truck Not Starting...
- 92 22re wire tap for dual battery switch
- mechanical temp gauge?? 3vze
- Solid axle swap?
- What am I looking at? W56? R151F?
- since the toy is down what else
- Splash shield question?
- 22r timing, plugs and power
- trouble code 51
- starter question
- Fuel problems on 1988 3.0
- ecu clicking noise
- running with out a muffler...
- Looking for an 88-92 3vze distributor plug wire diagram
- here we go again failed emssions
- 3VZE sloooooow start especially cold
- Timbrens causing rough ride (rear)
- 22re exhaust problem
- 22R terrible cold start/idle
- IFS Wheel Hub Assembly
- Engine Swap
- 89 Toyota SR5 Lift problems.
- 3.0 v6 tps sensor / timing. need help
- Idle problems with 22r
- Question : New fuel pump, and fuel pressure
- engine knock after oil change 22r
- 88 3.0 Manual Trans
- 87 22rte pickup stiff suspension
- hard starting when engine is warm
- Broke the shock mounts again..... some help would be nice....
- 3.0 Rough, Code 12
- Engine overheated bad last night, need to know what to check
- Slight engine rattle, no power no throttle response
- Brake Fluid Sensor wiring
- "94 4Runner
- 93 4runner
- need some help with my 22re
- Still glowing...
- 4runner pulling to the left under hard braking.
- information on 3zv-e needed
- Throttle body and intake filled with gasoline.
- Headers without cam or crank upgrade
- grinding noise......
- Fuel pump assembly thread size
- Blinking O/D Light
- Master Cylinder leaking for mystery Screw
- What just happened to my truck?
- 88 pickup
- CSB Nightmare!!!
- Bought an '87 4Runner
- Transmission/Swap Questions
- 1991 2wd Pickup, W56 transmission extension housing removal and replacement
- 3rd member problems
- Blown head gasket 1993 V6 4x4
- 88 3vze oil pressure switch location.
- 86 toyota vacuum line troubles please help
- 86 4Runner 22RE Starts up and sputters
- Ford driveline swap 90 4runner
- 94 3vze pickup blowing white smoke after flamethrower injector install???
- Automatic transmission experiencing intermittent problem...
- Please send me the link for a front axle swap.
- 3.0 wont turn over after intake manifold gasket replacement
- 3vze igintion timing
- speedo lag
- Anyone around my area to help?
- Bad 3VZE start up problem. Any help?
- Powersteering issue
- power window going up really slow
- 94 4runner electrical issue
- Help. Tps issues 88 3vze
- 94 4runner won't start!
- Ideas for new tailgate
- helping a new found friend with loss of power... ideas?
- 3.0 skipp/stall
- Fuel Problems on 88 3.0L Pickup SR5
- Low RPM at startup, high at operating temp?
- ifs and a lunchbox locker
- location for fan switch, thread/diameter?
- 92 4runner
- 91 Toyota 22re 4x4
- '95 3.0 rear main seal gasket?
- Clunking at take off 93 toyota hulix
- Which VSV is which?
- Stupid not to ask
- searched and searched but issue remains.
- 87 4Runner Won't even turn over - Just clicks now
- Leaking coolant
- top end knock?
- How to find out what gear are in my truck?
- Vacuum hose part name or part #
- Intermittent Catastrophic Coolant Leak
- timing chain guide
- Looking for some help with regearing
- Recirc or fresh,THAT is the question...
- 91 3vze Auto stalls when slowing down on LPG
- 1994 P/U Speedo??
- Power steering
- Toyota Pickup SAS and shackle angle
- 22re rebuilt engine?
- Replacing a 7/8" master cylinder with a 1"
- 92 V-6 Floods
- fuel pump replacement
- Auxiliary Air Valve - Adjusting/Cleaning?
- 95 runner auto auto transmission replacement
- Newbie 3.0 to 3.4 Conversion PLEASE HELP
- How many cranks before start?
- Tansmission cable placement
- 86 runner 22re swap wiring help
- Coolant/Oil leak troubleshooting. New 88 Toyota Pickup owner.
- symptoms of a bad Fuel pressure regulator
- ECM ECU voltage at vs - e2
- 22re rough idle, cutting out... help!
- backspacing question
- Broken door lock
- b+ wire on alt falling apart help
- rear locker or limited slip
- 1992 Toyota Pickup Tick Noise
- Brand new long block, rear main seal leak from housing bolts
- 1990 plow truck build
- 87 4runner center console question
- factory carb spacer
- Will these shocks fit? And will any modding need to be done?
- heater core r&r
- 93 pickup
- 1994 toyota pickup dlx transmission shifts hard while cold.
- need to find parts for my truck
- Help finding the right led light
- 89 4Rnr IFS wandering steering, running out of parts to replace!
- 4 Wheel drive question
- 86 4runner idle problem
- Injector install gone bad - real bad. Help!
- Transmission solenoids (in transfer case)
- 22re Headgasket - Some questions before trying again
- how to quiet my intake after location swap
- new guy. new toy
- My '86 won't hardly Idle?
- Intro: me & my 90 with a 1kd
- 1994 Truck 22-RE Missing on Cyl. 1
- Thermostat and Lower Radiator Hose
- 22RE no spark
- Drewski's '88 build
- 89 v6 3.0 rebuilt
- Factory speaker box
- Resetting check engine light 22re
- Rear window won't go up
- Almost time for the 3.4 swap!
- 94 3.0 auto loss of power
- Difference between Japanese and US Master Cylinders
- Bogged out 87 RTE
- White smoke, slight loss in power, then dead 94 3.0
- Weird question.
- Vacuum leak located
- Late production '95 4Runner 3.0vze??
- my new(to me) yota
- Speedometer drops below zero, always 10mph slow
- Control arm leak?
- 86 22re oil question
- Starter not engaging?
- 1st gen 4Runner horn stopped working.
- 89-95 downpipe on an '88?
- Lets talk about Rotella T6
- Removable rear windows
- 3vze question
- Difficulty on replacing Fuel injectors
- 1990 4 runner
- 1992 Pickup rear brakes surging/pulsing
- Auto 2WD Trans Help
- V6 Automatic Transmission Removal
- What the heck? V6 diff with 4cyl crush sleeve?
- Brake bleeder tube size
- Where can the 3vze leak oil from ?
- High Idle
- N/A vs. Turbo VAFM
- General EGR question
- Reverse headlight conversion
- Timing erratic rough idle
- External fuel pump??
- Help needed identifying the power steering pump & reservoir in my 93 4runner
- 1992 Pick-up Heater and horn don't work
- Toyota Gremlins...need help
- Fuel gauge / amp meter ind problems
- best way to winterize v6 without radiator installed?
- A couple problems trying to figure out
- Milk shake
- What 89 Toyota A/T Part????
- Broken Oil Pump 22RE
- My 94 forced induction options.
- Need some help, 1992 4runner
- High beams suddenly stopped working
- What size headlight replacement?
- What tool do i need to remove the Valves
- fast/high idle problem solved
- Jennifer
- Rusty floorboad cost to fix?
- 89 4runner sagging
- WTH is this, and why is it leaking??
- 91 Runner Engine Died after repairing fuel line
- Gen 1 rear bumper on a gen 2 4Runner
- Cv axle and lift leveling 89 runner
- Hello - Newbie
- Doug thorley 3.0 header guys ....
- bad acceleration and sputtering at low rpm
- idle air control valve question??????
- Your 22RE Timing Chain Mileage?
- 22r to 22re
- 87 4Runner fuel pump not kicking on. Suggestions?
- 88 Toyota pickup, Yukon 4.88's
- 1987 Rear Glass - What the heck do I buy?
- Interior rear view mirror wiring
- A TPS question.
- 82 supra MAF pic?
- Starting issues after alternator fire
- Didnt short out circuit when adjusting timing
- Mysterious power steering leak
- 3vze/auto 94 4Runner PUKED antifreeze out of front of engine
- 2WD with 4WD Suspension
- Feels like misfiring in cold
- Coolant in my exhast
- no brake pressure after sitting for awhile
- throttle body gasket
- Fuel tank size for extra cab?
- coolant leak only after engine is turned off
- spark plugs seized
- Bad Fuel pressure regulator
- cv shaft vibration?
- Bad Igniter?
- IFS stock skidplate
- Bent center link
