here we go again failed emssions
Old Nov 9, 2013 | 03:25 AM
skinny's Avatar
the truck =94 4runner 3.0
the test 2 speed idle
2500 rpm idle
limit reading limit reading
hc 200 1693 200 432
co 1 .63 1 .02
so not knowing much about the readings I'm told it dumping raw fuel into pipe
to look for bad plug
or wire
will be at it today looking
yes its running bit rough and low idle
but that is all random
it coded a code 26 only during test but hasn't mostly during driving
but it never sits and idles much in and go
plugs wires cap rotor injectors fuel filter all replaced in summer
Old Nov 9, 2013 | 03:58 AM
bone collector's Avatar
I really couldn't understand what you are trying to say. be clear and specific. the only thing I could understand is code 26
code 26 is rich condition.
here is what to look at:
Engine ground bolt loose
Open in E1 circuit
Short in injector circuit
Fuel line pressure (Injector
. leakage, etc.)
Open or short in cold start
injector circuit
Cold start injector
Open or short in heated oxygen
sensor circuit
Heated oxygen sensor
Engine coolant temp. sensor
Volume air flow meter
Compression pressure
that cam from the fsm. good luck,
Old Nov 9, 2013 | 04:36 AM
skinny's Avatar
the test says its way out on hydro carbons
so I'm told it has way to much un spent fuel
ie rich
which goes in line with code 26
i have replaced lots of normal stuff to try to cover the stuff that comes up with code 26
and once again still messed up
and looking for more direction
I was hoping someone could see test results and have a clue as to what might be causing things to be so high
so I could narrow down the search
Old Nov 9, 2013 | 04:45 AM
when is the last time you changed/check the o2 sensor? it has a lot to do with fuel mixture.
http://personal.utulsa.edu/~nathan-b...01heatedox.pdf
the other likely suspect is the engine coolant sensor. If it is bad the engine thinks its still cold and continues to activate the cold start injector sending extra fuel into the engine.
http://personal.utulsa.edu/~nathan-b...98engineco.pdf
if those check out try the afm.
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
Old Nov 9, 2013 | 07:13 AM
Discombobulated's Avatar
You say new injectors, what kind?
Old Nov 9, 2013 | 07:44 AM
bhawkin00's Avatar
You say it runs a bit rough? I would do a compression check to verify your not fighting a burnt valve...most of the 3.0's i've seen with a misfire,had low compression.
Old Nov 9, 2013 | 08:11 AM
guzzirik's Avatar
If you have a dead miss, that's easy to find. Pull plug wires 'till you find the offending cyl. Old trick. Hold a dollar bill by the end and hold it near the tailpipe.If it jumps away and then sucks back to the pipe in a rhythmic fashion you either have a tight or burn't valve.
Old Nov 9, 2013 | 07:21 PM
skoti89's Avatar
The cold start injector only pumps for a couple of seconds...unless it can keep turning on over and over again...
ladybugRC
458
Aug 21, 2020 10:41 AM
Longbed 90
Mar 11, 2019 12:38 PM
Chicken12
Oct 14, 2015 03:54 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
