Resetting check engine light 22re
Old Oct 26, 2013 | 09:08 PM
SqWADoosh's Avatar
I have fixed my problem and now would like to reset my CEL to see if I have another. Can anyone tell me what the process is on our trucks?
Old Oct 26, 2013 | 09:35 PM
HighLux's Avatar
unplug the battery for a few minutes
Old Oct 27, 2013 | 05:04 AM
rworegon's Avatar
.....remove the negative battery cable for a minute or so.
Old Oct 27, 2013 | 08:41 AM
SqWADoosh's Avatar
I did do that for at least half an hour....
Old Oct 27, 2013 | 09:01 AM
rworegon's Avatar
....now you need to read the CEL that appeared after the battery was disconnected.
Old Nov 2, 2013 | 11:41 AM
SqWADoosh's Avatar
Is there a fuse to reset codes? I remember seeing it somewhere in the FSM but can not locate it now. If so does anyone know which one?
Old Nov 2, 2013 | 12:09 PM
HighLux's Avatar
take both battery cable off. touch them togther and leave for 20 minutes.
if the light is on after that.....there is something wrong
Old Nov 2, 2013 | 12:28 PM
SqWADoosh's Avatar
Why touch them together?
Old Nov 2, 2013 | 12:35 PM
combatcarl's Avatar
Pull EFI fuse. Under hood. Then bust out some beer, forget where you put the fuse, go find another one, then find original in your pocket. Then replace.
Sent from my NSA screened iPhone using YotaTech
Old Nov 2, 2013 | 12:42 PM
islanti's Avatar
If light still comes on then you didnt fix the issue or theres another. Check code again
Old Nov 2, 2013 | 12:44 PM
SqWADoosh's Avatar
I've heard to pull the one in the kick panel. Now under the hood. Which is it?
Old Nov 2, 2013 | 01:04 PM
islanti's Avatar
Theres a fuse box. Pop off the cover and pull the one labeled EFI (see underside of cover). Take 30 seconds to check your engine oil and the condition of your battery terminals then replace the fuse
Old Nov 2, 2013 | 01:33 PM
combatcarl's Avatar
You can leave out the beer drinking, I guess. But that's how I always seem to do it, along with checking other stuff. It's the fuse box under hood, right fender.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
