Clunking at take off 93 toyota hulix - YotaTech Forums
LinkBack Thread Tools Search this Thread
Old 11-02-2013, 10:03 AM   #1
Hello,
I have a 93 toyota hulix with a new 2.4 TD motor with a auto tranny. Just wondering if anyone has had a problem of a clunk at take off from a stop once in a while. Trying to narrow down what It could be.
Seems like it's felt in the seat and pedals.
Also after off-roading a couple weeks ago there seems to be loud squeaking when turning. Possible cv shaft? Boots look fine. and then almost metal on metal sound when full lock going over anything.
Thanks for your help.
Spyker is offline   Reply With Quote
Old 11-02-2013, 10:20 AM   #2
Sounds like a U joint to me for the clunk when stopping and going its a quick fix costs about 40 or 50 bucks
Squeaking while turning sounds like a dry cv shaft to me
Yota94ext is offline   Reply With Quote
Old 11-02-2013, 10:55 AM   #3
HighLux's Avatar
When I got my 87 back and got it running. I would take off and here weird noise from the back. I was pretty freaked at first. Was the spare tire mount deal swinging around. Kid I got my runner back from had taken tha spare out.
Maybe you will get that lucky...
HighLux is offline   Reply With Quote
Old 11-02-2013, 11:16 AM   #4
That actually happened to me with my pick up after I did the U joint and thought another one was going haha
Sometimes the steady bearing goes to in the 2 piece drive shafts but then you'd notice vibration while driving aswell
10$ at pick apart for a used one
Old 11-02-2013, 11:43 AM   #5
Hey thanks for the quick responses guys!! Appreciate it. Will start with the ujoints and cv shafts. Will update when done.
Old 11-02-2013, 12:10 PM   #6
Also have you ever greased your truck reagular maintenance like that will reduce things like this happening it kinda sounds like you went on a wheel and worked the grease out or just never greased and they are dry. try greasing your whole truck when you do the U joint before doing the CVs could save yeh a few bucks without doing the harder labor
Old 11-02-2013, 01:05 PM   #7
Yep greased in June. Due for another ASAP. Will do that first before cvs.
Old 11-02-2013, 02:08 PM   #8
RJR
U-joints for the clunk, steering stops for the creaks and groans while turning. Steering stop noises are annoying, but not harmful. You can put some grease on them to quiet them down for a while but there's no real good long-term fix. Just learn to appreciate the uniqueness of your truck.:-)
RJR is offline   Reply With Quote
Old 11-03-2013, 04:43 AM   #9
Ah steering stops. Makes sense. Thanks RJR and everyone for the quick responses. Very helpful.
Last question. Are these specific parts of the drivetrain for the Hilux the same as the counterpart 4 runner? I'm guessing they are.
Old 11-03-2013, 06:31 AM   #10
osv
when you unbolt the ujoints, check the rotational play at the flanges... mine has over an inch on the rear pinion flange, so it clunks... not sure what i'm gonna do, there isn't hardly any in/out play.
I would guess that the parts are the same, for matching years.
osv is offline   Reply With Quote
Old 11-05-2013, 08:51 PM   #11
Well I did the u joints and lubed up everything. Seems to have worked great. Although I did have to cab it down to a local shop and have them press the u joints out as mine were seized in. They even had to cut one of the old ones out with a torch. Must have been a original. Great thing about that is they didn't charge me anything for the work. Which is awesome.
Pretty much everything on the Hilux is perfect now. Will be making a build thread for the future diesel 4x4 fun.
Old 11-05-2013, 09:13 PM   #12
HighLux's Avatar
Glad you got her fixed!!!
Look forward to more from you sir.
White tire letters in, or white letters out? Scenic WonderRunner Off Topic Talk 40 10-11-2017 07:41 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 09:27 AM
FS[International]: Supra AFM crashburnoveride Misc Stuff (Vehicle Related) 3 08-28-2015 09:20 PM
Do I bother fixing it? 1993 3vz-E 4x4 Colington 86-95 Trucks & 4Runners 13 07-21-2015 05:24 PM
3vze help nick b 86-95 Trucks & 4Runners 4 07-11-2015 04:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
