'95 3.0 rear main seal gasket?
Old Nov 2, 2013 | 02:15 PM
gareth's Avatar
So, I have this engine on my stand. I decided to fix the oil pan leak while it's out. I also am replacing the valve cover gaskets (on leaks slightly), and on a whim decided to get a rear main as well.
Here is my question.
I have a Felpro rear main. I am replacing some other brand aftermarket rear main which was not leaking.
Both the dry seal cover on there and the new Felpro seal have a gasket for teh seal cover.
The FSM says to just use FIPG around the cover.
I have a tube of FIPG on hand for the oil pan and baffle plate.
What is the consensus on the rear seal holder?
Paper gasket, FIPG, or some combination thereof?
I just need to grease the seal, make a decision and I can slap the bottom back together, flip her over and hit the VC's.
Thanks to those with experience for the voices of wisdom in advance.
Old Nov 4, 2013 | 10:23 AM
gareth's Avatar
In case anyone was wondering...
I decided "when in doubt go by the FSM."
It called for FIPG and no gasket, so that is what I used.
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 11, 2015 07:21 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
