Fuel Problems on 88 3.0L Pickup SR5
Old Nov 3, 2013 | 01:53 PM
poolboy85's Avatar
I was driving my 88 3.0 today and it suddenly died. Pulled it home. Tested a few things and found that the fuel pump was not coming on, turned the key on and pushed in on the air box sensor.
I also done the paper clip in the diagnostic code center and still would not start or fuel pump come on.
I took the bed off because I was needing to redo some wiring on the truck anyways and took the fuel pump out. After I took it out I hooked it up to a battery and the fuel pump would come on. So thinking it might be stuck I hooked everything back up and it is still not doing anything.
Does the relays go bad or fuses or what else should I check on.
Thanks for all the help!
Old Nov 3, 2013 | 02:21 PM
bone collector's Avatar
http://personal.utulsa.edu/~nathan-b...87fuelpump.pdf
use this link to work through some troubleshooting.
did you blow a fusible link?? does the fuel pump turn on when the +B and FP are jumped in the diagnosis port?? good luck
Old Nov 3, 2013 | 03:00 PM
poolboy85's Avatar
Bone collector, when I jumped the +B and FP it still would not turn on. I take a look at these and see what I can come up with. Thanks!
Old Nov 3, 2013 | 03:05 PM
poolboy85's Avatar
Anyway to check to see if the relay is good without replacing it and also where is the 15 AMP fuse at, I can't seem to figure it out.
Old Nov 3, 2013 | 03:59 PM
Old Nov 3, 2013 | 04:00 PM
http://personal.utulsa.edu/~nathan-b...96circuito.pdf
This is the COR relay test
rbravo1
Jun 29, 2015 01:34 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
streetuner15
Jun 18, 2015 10:59 PM
ShaunKris
Jun 17, 2015 04:33 PM
Land yacht
Jun 28, 2002 09:53 AM
