- Weird electric window problem...
- Engine stalls when its wet
- The infamous 22RE starter problem
- R150 Transfercase input shaft!
- Gen 2 alternator - pics - brushes and rotor - need advice
- TDC for Valve Adjustment?
- Chirping speedometer..
- My 95Runner needs help so she can climb things feed me your knowledge yotatech!!
- Stinky Exhaust Post headgasket
- 1986 Hilux Surf RHD Turbo Diesel on Craigslist
- Help please.....odd knocking in top of motor
- 4Runner body on pickup frame?
- check engine light after batt intake swap
- Wont rev past 1500rpm, no codes
- 95 toyota pickup rear wheel bearing replace
- Head Gasket Recall Question...
- Codes 41 and 52
- Transporting a 22re
- Post pics of pickups with 2" lifts and 33's
- Parking brake light constantly on
- 86 Toyota PU, how do I clamp this cap?
- some more 5spd help
- Speedometer cable
- Garage fit issues ? Lifted 1g 4runner seeks 35" of pleasure and roof over it's head
- Power (elc.) problem
- Can I use Bosch R3 Platinum R2 spark plugs in my 91 4Runner???
- hacked wire harness
- 1990 Toyota Xtra Cab BUILD
- Doetsch tech vs monroes vs any other brands..
- Herculiner on 90 frame
- My new 86 4runner..project
- My 1989 4Runner
- Thread Inserts Exhaust Manifold???
- Question concerning timing 3vze
- Rough idle and misses in the rain 22re
- Broke down!!!
- Broke down with shredded water pump belt
- toyota hilux surf ssr limited auto transmission issues
- Exhaust Manifold Stud replacement
- Seal
- Step By Step Guide for 22R-E Head R&R
- Question About The Finish/Plating On The Front Wheel Spindle Of An 88 4wd.
- wheel well
- TPS Screw removal
- is there a trick to removing the front diff
- PArtially Working Gauge Cluster, can't figure it out.
- rebuilting a 90 4runner
- 3.0 just dies after 15 mins
- Idle surging on 3.0
- Help! Broken down away from home
- first gen 4runner tow hitch
- Slamming hard, new shocks, removed bump stops, now what?
- 3vze intake manifold question ?
- valve adjustment...
- '95 4Runner Brake Lines
- 3vze tuning suggestions
- what is this?
- AC not in 93 ex cab?
- 7mge Coil Swap
- transfer case
- Code 42 speedometer weirdness. HELP!!!
- 1990 4runner accelerating issues
- 3vze weird running issue!
- 87 yota ext cab on a stock non ext frame?
- Shifting issues!! 94 4runner
- wont start unless i pull the negative battery cable first?
- Passenger window
- Now that's a heater control valve issue of a different color.
- Pulling my hair out with an 86 4runner
- 89 4runner top
- Help solve electrical puzzle (coolant gauge)
- which O2 sensor to replace
- Anyone know what this is for?
- letronic cluster in 90 yota?
- Last Car Standing
- 88 standard cab PU rear glass interchange
- manual hubs for the noob
- Make back window roll faster?
- locating leak... any help?
- supra MAF swap?
- 22re About to loose hope
- 22re head gasket replaced, will not run
- what to do with new truck
- 89 3.0l died while idling, now has no spark
- 1UZ swap exhaust manifold/header fitment
- Searching for a 87 toyota bed. and frame.
- Cats muffler & o2 missing
- By-passing the P.A.I.R VSV
- Another Trouble Code... 52
- rear window troubles! need help
- Identify this carrier
- 93 3.0 toyota 4 runner leaking gas under uppee intake down front of motor
- portable trail wirefeed welder ??
- 00-02 tundra brakes on 88 IFS 4runner?
- List of Toyota P/N's for Fuel Pulsation Damper and PCV Replacement
- 22re hard to start hot
- Will these fit without lifting truck
- 1993 p/u lowering question
- using Xtracab rock sliders on a regular cab
- Quality window regulator brands?
- Going Carb NEED everyone's advice.....
- main relay?
- Broken Fuel Line
- 22ret boost gauge line location?
- Pop in the steering
- new truck! :) what to replace
- 1988 22re sr5 pickup wont stay running? PLEASE HELP!
- Code 52 wiring to ecu?
- Lift question
- 89 yota pickup, power, but no crank
- Ecu question
- Which brake line goes where on lspv?
- starting trouble/ electrical or ignition?
- Intake Manifold Replace or Weld? Please take a minute to read
- Intake Manifold Gasket Bad Coolant Leak? PIC
- v6 engine removal
- disaster trying to remove bed
- Whats missing from my Washer fluid reservoir?
- 94 22re White smoke
- headlight assembly
- 1988 truck Saved from the crusher Rebuild Build
- 1995 4runner headlight help
- Truck Won't Start
- Pinging during criuse or let off throttle
- Really need help finding an ECU for a 1990 Toyota R-22
- 1988 pickup turns over but wont start..
- M4 relay getting very hot
- 89 efi turns over will not start
- Remove shock to replace cv on ifs?
- 1987 22r won't start!!!
- Liloscar 1988 4x4 pickup Build
- ebay balljoints kit
- Seat Belt Receiver Sleeve Question
- 4WD wont engage 1988 pickup
- 1992 Toyota pickup exhaust opinions
- How to tell if torsion bars have been adjusted?
- Correct Rim and Tire Size
- problem with truck not running right
- Will the timing be off or ?
- oem rebuilt carb or aftermarket? 87 pickup
- Get in... Turn key... Nothing... Then suddenly it starts... Wierd?
- how do I fix idle screw is not making change
- Replacement Bench Seat Options for 91 tuck
- Rear window issue/Parasitic Battery Drain
- Grinding noise on front end above 50mph
- Help! Stripped Rear Shock Mount Hole
- Lubrication for suspension,steering,bearings 88 pickup
- Replaced 3.0 head gasket now engine wont start.
- shock help
- Starter solenoid connector.
- cant find heat controls!!
- Cabin (roof) dimensions 1gen Runner
- Engine Swap?
- Best aftermarket brand radiator?
- Rough Idle/Won't Stay Running
- Truck will not turn on
- VF2A rebuild
- Running Rich Help
- Uneven wear on distributor contacts????
- Sliders - Notch or bend the pinch weld back?
- 86 22re-c temp gauge goes up and down ??
- Exhaust manifold studs and Helicoils
- Need advice on starting issue
- NEW amateur yota Rider! :D
- Looking for a mechanic in NorCal for a head swap.
- 94 v6 auto 4wd cold start issue
- Stuck in 4WD
- Side View Mirror Retrofits Base-DLX or SR5
- Auto hub to manual hub/stickey update
- 1991 pickup 5speed trouble
- 1993 truck front end swap with 1978 truck
- Idle surge!
- Plugs need to be identify? 86 T4R 22re Engine Harness
- Aftermarket headers for 22re?
- What is a good head gasket to use?
- Weird hot start issue.
- Whats these codes mean?
- Ball Joint Spacer Idea
- That dang code 24 won't go away
- oil every where, underhood and underneath
- 1991 V6 3.0 Replacing A/C Tensioner Pulley
- New Rims
- Replacing 92 r12 compressor with a 95 134a compressor
- 3vze sensor help please
- 1st gen 4runner clear turn signals (front)
- Fuel Problem '91 3VZE Truck
- 94 4runner 3.0 4wd Auto; Rev limited / no power
- Aisin rebuild!!!!!!!!!!
- 86 4Runner 22RE SR5 no start
- Ticking/rattling in valve train
- 87 pickup 22r, sputters, lack of power, an backfiring at the carb!
- Vortec or 22RE upgrades?
- 1991 22re not starting
- Different idle issue
- A/C gets hot when driving
- swap cab from '93 22re to '87 22r?
- Overdrive suddenly doesn't work anymore?
- Setting timing on an 87 22re
- OBD 1 reading
- Opinons on oil viscosity for 22re??
- Removing xtra cab rear trim
- 92 v6 3vze swap to a 89 v6 3vze
- frozen tie rod joint trick
- 90 toyota 4x4 speedo broken
- Fuel leak
- can't get alignment right
- What's this line?
- Light Mounting Ideas?
- No fuel issue 94 4Runner 3VZ
- How many miles per tank for 1st Gen Runner??
- 3.4 clutch fit a 3.0?
- My 22re is burning a lot of antifreeze?
- Yet another 22re POS...
- 1989 22re check engine/cracking or tapping sound
- Stumped on some timing belt issues
- 22RE keeps cutting out when driving
- Retard/Advance Timing After Header Install
- part availability
- dash lights - brake - battery - at oil temp
- Floor mats?
- Warn bumper help.
- Instrument Cluster swap
- Replacement Steel Chain Guide Rubbing Chain
- Does Centerlink include tie rod ends
- Bad Cylinder Head on 22re?
- Alright, time to get this 4 banger to actually bang!
- Tacoma console (cup holders) swap into a 1st gen 4runner
- 1993 4Runner Rear window circuit board relay functions
- 22re High Idle
- Rear window goes down with key, but not up.
- '93 4runner 22re rebuild advice
- Swapping seat belts in Extra-Cab ( front to rear )
- mystery bolt/adjuster
- Controll Arm Bushings - What's missing here?
- 87 22re oil pump questions...
- 22RE Head Repair: What do you think? (advice needed)
- Air shocks on 94 pickup
- So im stumped v6 toyota
- shock options for lift?
- 87 22re timing chain repair...*PICS*
- Stripped Threads Flange Nut-Fuel Filter
- HELP - truck in pieces and the springs dont fit!!!!
- R150f Help
- Rear window sizes 89-95
- Vertigo buckets
- After MArket injectors for v6. any thoughts?
- 3vze Hesitation between 1700-3000RPM. Gurus help me!
- Inconsistent symptom no start
- 93 runner with 3.0 wont start
- Fuel Pressure regulator
