Warn bumper help.
Old May 28, 2013 | 03:37 PM
colbyman's Avatar
Warn bumper help.
so i have a 1992 4runner that i just got back and did a 3.4 swap in it....it has a 3 inch body lift. my question is that do the warn bumpers bolt onto the same place as the facxtory bumpers or do you have to fabricate brackets? heres the bumper im talking about along with a picture of my 4runner because i just want to show it off:
Old May 29, 2013 | 12:14 AM
wyoming9's Avatar
Red face
Most bumpers come with new brackets.
Did you buy this new or used.
Can you build your own brackets??:jessica:
Old May 29, 2013 | 04:45 PM
dcole's Avatar
I have the rockcrawler front bumper on my rig...
the supplied brackets are not intended for a body lifted truck, they will need to be modified or new brackets fabricated for it to bolt up without having a large gap between the bottom of your grill/ top of your bumper
Old May 30, 2013 | 09:21 AM
highonpottery's Avatar
with pretty much all the aftermarket bumpers that aren't custom-fabbed, they will not be supplied with brackets to compensate for a body lift. mainly, i'd say the reason is liability since lifting the bumper will change the ratings on the bumper due to changed geometry and multiplied leverage on the frame since they all bolt in place so Joe Blow can install them in his driveway. I would think a big company like WARN would have these ratings on their products, whereas most smaller companies don't bother due to cost and just classify them as "offroad only".
with a 3" lift on the front bumper, you're risking quite a bit if you plan to stick a winch inside or hit something with the bumper. what you're now experiencing is one of the many downsides to having a body lift on a rig.
i'd say you have to make some new mounting brackets and somehow brace the heck out of them to compensate for the significantly multiplied leverage it will be putting on the frame.
Peevedkitten
11
Aug 31, 2015 06:57 PM
izzmee
Aug 17, 2015 10:20 AM
priest16
15
Aug 6, 2015 07:43 AM
kvanzandt1
Jul 18, 2015 10:15 AM
Odin
Jul 15, 2015 09:28 PM
