wont start unless i pull the negative battery cable first?
Old Jun 12, 2013 | 04:32 PM
vamped400's Avatar
I am having a problem with my 95 yota pickup where I have to pull the negative battery cable for at least a minute before it will start. even if i just had it running. also if i stalled it out, then bump started it, it will fire right up. any ideas on why it would be doing this? i am lost..
battery is good, alternator is also good . it just seems i have to reset somthing before it will turn it over with the electric start
Old Jun 12, 2013 | 04:41 PM
rworegon's Avatar
Is there an alarm system/kill switch system that may be causing the issue?
Old Jun 12, 2013 | 04:48 PM
vamped400's Avatar
it very well could be, i wonder if there is a way I could bypass/ disconnect it?
Old Jun 12, 2013 | 04:51 PM
rworegon's Avatar
I'm not up on those systems, but someone who is will likley chime in. Do you know what system is in there? Is this a new rig to you?
Old Jun 12, 2013 | 04:56 PM
vamped400's Avatar
I am not sure on the system part. This truck is 100% new to me, i bought it not running with a bad motor, put a motor in it and am now facing this problem lol. it was sunk in about 3 ft of water and sat for 5 months as is before i got it
Old Jun 13, 2013 | 12:20 AM
wyoming9's Avatar
Red face
If this does not have a Alarm
I would almost guess your problem is having bad grounds .
i am not sure what this bump starting is??? Does it involve using or threatening with a real big hammer??
In this condition you have no electrical power at all??
Lights work, radio etc??
Engine does not crank??
Engine Cranks but does not start??
are we dealing with a manual or auto??
Old Jun 13, 2013 | 07:31 AM
scope103's Avatar
Originally Posted by vamped400
... it was sunk in about 3 ft of water and sat for 5 months as is before i got it
Oh, god .....
Every electrical connection is now suspect. If you get it running, you should be prepared for it regularly dying without warning.
Please, please, don't try to sell it unless you disclose that it sat in water for 5 months. Better yet, don't try to sell it at all.
Old Jun 13, 2013 | 09:46 AM
Gamefreakgc's Avatar
Pulling the wire resets the CPU and the diagnostics. There's a lot of sensors that correct only after two starts. So it'll run on factory setting the first, then adjust when you go to start the truck again. I have no idea which one it might be... that's a wild goose chase.
Old Jun 13, 2013 | 01:03 PM
vamped400's Avatar
bump starting is pushing it down the road and then putting it in gear and it will fire up. all the lights work and everything, and when it cranks it always starts. just after i have it running, i will shut it off, then i have to disconnect the negative battery cable for it to start again. it is a manual
I have a complete parts truck that i have been stealing parts off. so far i have stole the computer out it but no luck. I am going to try to replace the negative battery cable next but i doubt that will work. what else could i try and replace?
I dont plan to sell it, i have way to much money into them now haha
Old Jun 17, 2013 | 04:33 PM
vamped400's Avatar
Anyone? Btw the truck wasnt sunk and left in the water for 5 months lol it was sunk, pulled out and left for 5 months. I finally got it running perfect now, just this is my only problem stopping me from putting it on the road
Team420
Jan 12, 2021 04:57 PM
alfonz33
9
Nov 16, 2015 09:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
88Toy
Jul 4, 2015 02:11 PM
Taz22R
Jun 21, 2015 04:44 PM
