My 22re is burning a lot of antifreeze?
Old 05-29-2013, 08:11 AM
rydholm11211's Avatar
As soon as I start my truck it builds pressure in the radiator real fast , and has a lot of white smoke out the tail pipe, so I am pretty sure it is burning antifreeze? So I think It has a bad Head Gasket, but I did a compression check and got 180 psi across all four? So do you guys still think it is the head gasket? My plan is to buy a rebuild head, and change the head gasket and timing chain? And I think that should solve my problem? What do you guys think? thanks.
Old 05-29-2013, 08:22 AM
snobdds's Avatar
Anytime you have coolant issues, your first test should be a coolant pressure test. A leak can be external to the combustion chamber and a compression test would show normal. But it does sound like a HG leak...
Old 05-29-2013, 08:59 AM
How do you do a coolant pressure test?
Old 05-29-2013, 09:10 AM
snobdds's Avatar
Plenty of write ups if you google it.
Then go to your local autoparts store and rent a tester if you don't have one.
RatOmeter
10-22-2015 03:17 PM
kcaudill
07-20-2015 12:06 PM
PlayAwhile
07-20-2015 11:36 AM
rushw
07-18-2015 01:46 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: My 22re is burning a lot of antifreeze?
