Auto hub to manual hub/stickey update
Old Jun 3, 2013 | 04:32 AM
seabee 86's Avatar
I checked the stickies for info but all the pages are gone so I'll start a new thread.
My current hubs say, "Automatic locking hubs" on them. I bought new manual locking hubs and want to swap them out, but I hear it's not so straight forward. Any suggestions or advice? Thanks.
Old Jun 3, 2013 | 06:40 AM
redbayredneck's Avatar
What year truck do you have? There is a difference between ADD and Auto-Locking hubs.
Auto locking hubs are pretty easy to swap out, I swapped them out in my '85 in no time.
Old Jun 3, 2013 | 06:47 AM
seabee 86's Avatar
Wow my bad. 88 4cyl 5 speed. I'm pretty sure they're auto locking. I'll post a pic later today
Old Jun 3, 2013 | 08:25 AM
brianh699's Avatar
It's pretty straight forward, you need to get some parts to do it though. You will need (2)90214-42030 claw washers (4)43521-60011 54 mm nuts and (2)90215-42025 lock washers. Make sure you set bearing preload properly when reinstalling, that's it. Warn sells a kit that has all these parts but I found it cheaper at the dealer.
Old Jun 3, 2013 | 08:58 AM
You can get a kit at Trail-gear or and drop-shipper from Wabfab then
Old Jun 3, 2013 | 09:27 AM
seabee 86's Avatar
I'll refer you to a previous thread entitled,"to a particular vendor..." in regards to your last suggestion. The kit itself, however, is a great idea. I'll Google some when I get home.
Old Jun 3, 2013 | 09:30 AM
He is just the main trail-gear drop-shipper I know... There are a few others that drop ship directly from trail-gear for a slightly lower cost than buying direct from trail-gear.
Old Jun 3, 2013 | 05:53 PM
seabee 86's Avatar
This is my hub. I don't think it's ADD
Attachment 92695
Old Jun 3, 2013 | 06:51 PM
brianh699's Avatar
That's definitely an auto hub not ADD
Old Jun 3, 2013 | 06:57 PM
seabee 86's Avatar
My thoughts indeed.
Old Jun 3, 2013 | 07:18 PM
brianh699's Avatar
This is a pretty good write up on the wheel bearing preload procedure. It's not the FSM procedure but I've always used it and have never had bearing issues.http://www.off-road.com/trucks-4x4/t...ent-18322.html
Old Jun 4, 2013 | 04:08 AM
Since its auto, its easy. Just take the old hub off, add the swap kit (two washers and a nut on each side) and put the new hub on. You can go ahead and do the wheel bearing if you want, but you don't have to touch it at all. I didn't when I did my swap, and I haven't had any issues.
Old Jun 4, 2013 | 04:11 AM
There is a step-by-step floating around the internet that I used when I did my hub swap, but I can't seem to find it. Just google -Auto to manual hub swap.
Old Jun 4, 2013 | 04:22 AM
PETDOC's Avatar
Seabee, I've got an '88 4Runner 5 spd manual, 22re and it has automatic locking hubs which have failed for the second and last time. I bought some re manufactured Aisin manual hubs and will perform the swap shortly. I found a YouTube video using a Google search that demonstrates removal of a hub. Because of it I purchased a recommended circlip pliers from Sears and a brass drift off EBay. I got the required 2 washers and 54 mm nuts for each side from Wabfab. He sells a kit for replacing automatic hubs with manual hubs for about $45 that includes the nuts and washers for each side and a 54 mm socket. They were drop-shipped from Trail-Gear. After I had ordered the kit I was looking at Wabfab's web site and it appeared it may have been cheaper to buy the parts individually.
Based on Redbayredneck's comments I suspect you may only need one 54 mm nut for each side as there is already one present??? My understanding of the torquing procedure recommended in the FSM is it is required if the wheel bearings have been re packed, otherwise I assume you can merely torque the two nuts to final spec.
Old Jun 4, 2013 | 10:20 AM
FOUND IT!!!
http://www.4x4wire.com/toyota/tech/autohub/
The swap is extremely easy.
Old Jun 4, 2013 | 01:59 PM
brianh699's Avatar
You do need 4 the nut on the auto hub is different it has threaded holes in it to screw the clutch into
Old Jun 4, 2013 | 02:07 PM
dropzone's Avatar
Fossilized
Never was a sticky for converting auto hubs to manual..
Old Jun 4, 2013 | 06:01 PM
Gizler00's Avatar
X2 on the above. You DO need the 4 54mm nuts and washers. The auto hubs only have one nut that has a fixed washer on it and has threaded holes to hold the auto hub.
We ordered them from Rock auto.
Here's the link. You have to order two sets
http://www.rockauto.com/catalog/x,carcode,1272170,parttype,1616
Old Jun 5, 2013 | 04:18 AM
seabee 86's Avatar
Yes there was
https://www.yotatech.com/forums/f116...tickys-242840/
Click on the link labeled, "Manual Hub 101..."
Old Jun 6, 2013 | 04:05 AM
seabee 86's Avatar
I see my second post never went up so lets try this again...
Thanks for all the help fellas. I got way more info than I could've asked for, I'll keep you all posted on the progress. Thanks again!
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
