A/C gets hot when driving
Old May 31, 2013 | 11:43 AM
TheLoneRunner's Avatar
My A/C is weird I cant figure it out when at a stop a/c blows cold the faster I go the hotter the A/C blows I checked condenser fan a/c clutch and its fully charged any ideas?
Old May 31, 2013 | 11:49 AM
oh yeah mines a 95 4runner sr5 2x4 v6 3.0
Old May 31, 2013 | 04:05 PM
oldblue's Avatar
really need to put a set of gauges on there to see what the pressures are doing at idle and while reving engine.
Old May 31, 2013 | 04:17 PM
RSR's Avatar
RSR
Is your system overcharged causing it to freeze? Moisture in the system causing it to freeze?
Might be expansion valve failure.
Might be your heater control valve isn't sealing all the way.
Could also be your compressor switch and/or ac coolant pressure related.
Worst case, your compressor is failing and not getting to pressure? But it should be more manifest at low than high speeds I'd think. Unless it's a problem with the clutch/friction plate not engaging at high speeds.
AC systems are a pain... Parts excluding the compressor are cheap.
I guess drive at speed and then pop the hood and check your lines to see if they're icing up or warm to start. Trouble shoot from there. If icing up, remove coolant, or have system fully evacuated and moisture removed -- fancy machine looking something like a mini fridge on wheels in better equipped shops that removes moisture and sediment rather than just a little compressor/vacuum pump.
Old Jun 1, 2013 | 07:00 PM
thanks really have had nothing but problems since buying this damn thing lol
MO transplant
Apr 23, 2023 11:58 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
