Broke down!!!
Old Jun 16, 2013 | 07:10 AM
circularwooden's Avatar
Broke down!!!
After rubber necking all the bonnaroo rv's in the field off of I24 I noticed my alt & brake warning lights were on. While pulling into the rest stop on top of monteagle the temp gauge spiked. Poped the hood.....shredded water pump belt. Alt and water pump both spin and are not seized. What's the chances of the water pump being toast or intermittently seizing? Trying to make it to the nearest auto parts store. Thanks.
Old Jun 16, 2013 | 07:11 AM
Sorry for the double post. Trying to work off my iPhone and got an error message when trying to send.
Old Jun 16, 2013 | 07:38 AM
swampfox's Avatar
If the pulleys spin free and the water pump does not have any play it, could be just a bad belt. also check pulley alignment and for any loose bolts.
Old Jun 16, 2013 | 10:04 AM
wyoming9's Avatar
Red face
That is one thing that I always have is that belt.
trying to drive without one plan on doing at least a headgasket soon unless your real lucky.
Old Jun 16, 2013 | 10:16 AM
Chip N Sawbones's Avatar
Turn the heater on full blast if you're trying to limp along with no belt. Stop every time the engine starts to heat up too much.
Old Jun 16, 2013 | 11:38 AM
maachine's Avatar
buy 2 belts to keep a spare. i also always keep a big and small crescent wrench in my truck for those "just in case" scenarios.
Old Jun 16, 2013 | 12:20 PM
kelvinb's Avatar
if you can replace the belt you should be fine. do not dump cold water in the engine you will crack the block. if the coolant is empty let it sit with the fan running (as suggested above) if you didnt drive it long with the coolant temp gauge spiked i doubt you damaged anything.
Old Jun 16, 2013 | 10:01 PM
I got it going after about an hour to cool down. While waiting I took the ac belt off and put it on the water pump and alt. Ran fine for the rest of my 300 mile trip. Just didn't have ac. All the belts are replaced now with extras. Even though they were only 6 months old. Thanks for all the help.
Old Jun 17, 2013 | 03:53 AM
kelvinb's Avatar
So the ac belt worked as a temporary replacement? Good info to have if you're in a bind.
Old Jun 17, 2013 | 10:11 AM
Yes. The ac belt will fit the water and alt pulleys. I compared the length of the two when I got home and replaced all the belts. Their not the same length but very close. There's enough adjustment on the alt bracket to make it work.
Old Jun 17, 2013 | 01:52 PM
Bullet22r's Avatar
i would of used a shoe lace in a last ditch attempt if i didnt have any spares.
Old Jun 17, 2013 | 01:57 PM
brianh699's Avatar
Haha been there done that! Works in a bind
Obmi
Oct 4, 2015 11:30 AM
puddlepirate
Sep 29, 2015 08:02 PM
mtrdrms
Sep 26, 2015 07:12 AM
mxdw88
Sep 20, 2015 03:13 AM
yoterr
Sep 15, 2015 03:47 PM
