22re High Idle
Old May 27, 2013 | 09:27 AM
SqWADoosh's Avatar
22re High Idle
So having fixed my first and most major issue. I am on to my next one. My truck starts up and idles great. However after driving when I put the truck in neutral to stop my RPMs will pin at 1500 to 2000. If I rev the engine past 3k to 4k it will come back down. Any help with anyone who has come across this issue in the past is much appreciated. Thank you.
Old May 29, 2013 | 11:52 AM
SqWADoosh's Avatar
Anyone?
Old May 29, 2013 | 12:12 PM
snobdds's Avatar
Have you tried turning your throttle screw down when the engine is doing this?
Old May 30, 2013 | 01:26 PM
SqWADoosh's Avatar
I have not. My thought process was that if the idle is perfect on start up that wasn't the problem. Am I incorrect? As I said it seems to be happening as the engine gets up to temperature.
Old May 30, 2013 | 02:24 PM
YotaWoRx's Avatar
Throttle valve sticking?
Old May 30, 2013 | 02:48 PM
SqWADoosh's Avatar
How can I go about finding/addressing that?
Old May 30, 2013 | 03:42 PM
SqWADoosh's Avatar
So I adjusted the idle screw inwards and dropped my idle to about 750. Then got in the truck and drove around. Felt good at first but then it bogged down to about 400-500 when I gently came to a stop. When going into neutral while still carrying some speed I would idle around 1k-1500. So I'm thinking it is something else.
Old May 30, 2013 | 05:13 PM
YotaWoRx's Avatar
When u stop and the idle is high, get out and open the hood. See if u can close the throttle valve any more by hand.....
Old May 30, 2013 | 05:21 PM
snobdds's Avatar
If not your idle screw, then you must look else where. I would make sure your IACV (Idle Air Control Valve) is not cloged up and working well.
By the way, what engine are we dealing with?
Old May 30, 2013 | 06:01 PM
SqWADoosh's Avatar
Where is the throttle valve exactly?
Old May 30, 2013 | 06:02 PM
SqWADoosh's Avatar
After doing some searching I am starting to suspect the same thing. It is a 22re. I see what I have found out to be my "dashpot" just hanging to the side of my block. Is that what it is supposed to do?
Old May 31, 2013 | 11:02 AM
SqWADoosh's Avatar
Update. I have retrieved the check engine light that the truck is throwing. The video is found here:
Old May 31, 2013 | 08:01 PM
Every1sFavoriteGing's Avatar
I had the same issue a couple months ago. I took apart the intake and just cleaned the hell out of the throttle body with some good ol' Berrymans. Made sure to get all moving parts on the outside of it sprayed down with some penatrating lubricant just to make sure there wasn't any mud/sand stuck in there restricting anything. After that, never another problem.
Old Jun 1, 2013 | 10:33 AM
SqWADoosh's Avatar
Did you take off your tps before doing so? I'm reading that it can be damaged by the cleaner if not taken off?
Old Jun 1, 2013 | 12:36 PM
No I didn't. My TPS is outside of the body. I've got the 3VZ-E engine. If you can, I'd remove it given that the problem is most likely your IAC (Idle Air Control) Valve.
Old Oct 20, 2013 | 05:12 PM
SqWADoosh's Avatar
*UPDATE* Problem was solved by removing throttle body and deep cleaning it and all passages. As well as replacing the Throttle Position Sensor.
Old Oct 20, 2013 | 05:20 PM
Discombobulated's Avatar
Did you replace with new or aftermarket or used?? Just curious having some of the same symptoms figured if it's cheap enough I would try a new one.
Old Oct 20, 2013 | 05:21 PM
SqWADoosh's Avatar
I replaced with a brand new one for just a little over 100 bucks off of Amazon.
Old Oct 20, 2013 | 06:28 PM
Teuf's Avatar
And who adjusted the TPS????????
Old Oct 20, 2013 | 06:32 PM
SqWADoosh's Avatar
Well I did of course. The FSM has all the information needed to adjust it or there is a great write up on 4crawler as well:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
redneck17
Oct 29, 2015 09:09 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
ZONAYODA
Jul 13, 2015 07:17 PM
Nickdigg
Jul 7, 2015 06:04 AM
