Exhaust Manifold Stud replacement
Old Jun 15, 2013 | 06:44 PM
Dell Martin's Avatar
Exhaust manifold stud blew out, have found replacement stud, now stud will not fit (thread) into manifold. How can I get the replacement stud to thread into manifold hole?
Old Jun 15, 2013 | 07:52 PM
xXbrutalXcoreXx's Avatar
I'd recommend just getting a regular bolt of the same thread pitch and threading it in. Much quicker and easier IMO.
Old Jun 16, 2013 | 12:23 AM
wyoming9's Avatar
Red face
Those Studs are M10x 1.25 is that the size you bought.
Just how did it fail ??
Did it break off or just unscrew trying to take the night off??
Did the threads fail in the head if so a thread replacement might be your only repair.
Old Jun 16, 2013 | 07:37 AM
arlindsay1992's Avatar
Do not use bolts to hold the manifold on. The purpose of a stud is to allow you to twist without pulling, and pull without twisting. This helps prevent the relatively soft aluminum threads from pulling out. If you use a bolt, you will be much more likely to strip the threads out of the head.
How did the first stud come out? I know if they are loose it's possible for them to simply unscrew and fall out with no damage. If this is the case, the thread size is M10x1.25. Advance Auto should have two of the correct studs with two new nuts in a package. But if it was overtightened and the threads were pulled out, you will need to helicoil the threads. It's quite simple but the kit costs about $20 to $30 if you don't have it already.
Old Jun 16, 2013 | 08:13 AM
Stud simply loosened itself and blew out while I was driving.I was told to use a tap and make new threads,does that sound reasonable?
Old Jun 16, 2013 | 08:16 AM
Old Jun 16, 2013 | 10:00 AM
wyoming9's Avatar
Red face
I suppose that could happen. If you just had it apart and just had forgotten to tighten it up
Have the others worked loose as well??
If it just vibrated out there should be no need of having to tap any new threads .
Now if the rest are loose and the manifold has shifted it might make the hole off center making it not start in the thread .
There is no blowing out no pressure behind the stud unless your heads cracked then you have interesting problems.
Old Jun 16, 2013 | 12:58 PM
Scrussanation's Avatar
Only reason you would need to use a tap and die set is if you screwed up the threads or had to drill out what was left of a stud. Do what other people are telling you and just replace it. Never heard of one just falling out tho thats crazy. Best of luck
Old Jun 16, 2013 | 08:57 PM
I have replacement stud, stud will not fit (thread) into manifold??
Old Jun 16, 2013 | 09:14 PM
if your absolutely positive that you have the correct stud to replace original I would try useing the same exact tap for that stud to A)free any rust or debris that may be lodged in the crevices or B)lubricate and find a small detail brush to clean out the hole.... let us know how it turns out
Old Jun 16, 2013 | 10:38 PM
wyoming9's Avatar
Red face
If your sure you have the correct stud.
You have every thing lined up correct.
Maybe someone has tapped that hole to a different size people do strange things.
Old Jun 17, 2013 | 05:05 AM
Gizler00's Avatar
Did you get the wrong size thread stud?? Is there alot of just build up in the existing thread hole? I've also never had an exhaust stud just fall out on its own. I have however had tons of them break and rot away.
You can use the correct size rap to chase the existing threads and clean them up.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
