- 22re Distributer O-ring
- My Lower Ball Joints Have Straight Grease Fittings - Impossible to Reach.
- did i boof my new tps????
- LC coil color codes
- 86 22re alternator question
- AES High Output Alternator Install - with pics
- Tri-Y headers worth it or no?
- 86' 4Runner 22re EFI Head Gasket replacement
- Where is the fuel pump wire?
- 22re RACES at startup, intermittently
- Will truck run with speedo off?
- High Idle after Tune-up
- RF1A rear seal and bearing
- 3.0 pinging and cutting out
- Hard brake pedal
- new 91 runner, pics inside
- oil pressure
- Mystery wire/plug
- Replace No.2 Idler Pulley without pulling cam gears?
- 3VZE Timing Belt Tensioner ISSUES
- Can I run Redline MT90 in my transfer case?
- Another stupid idle thread
- After locker install and wheeling I have a new vibration
- Rear end noise at 40-50mph, rumble at part throttle.
- Custom Skid Plate
- TPS confusion
- Long travel front, rear?
- Bleeding Brakes
- pics of 22RE without smog crap
- looking for motor mount write-up
- Tailgat motor moving slower - thoughts on this motor
- 87 4x4 Rear Driveshaft Question
- 91 Pickup 4x4 22re vacuum hose?
- Fan question
- pulled me 22re and found...
- weird power window issue
- Remove Parking Brake Cable from Handle
- 89 engine 93 truck header Q.
- Battery/Alt. Problems
- Weird thrumming noise....90 4runner
- will a s10 bed fit?
- 93 truck electrical issue
- vacuum lines
- driveshaft center support not fitting in place
- Trouble with 94 22re
- 3vze lifter noise after machine shop - valve grind/set-up.
- Checking pulsation dampener, need advice
- leaking tranny?
- PUTNEY'S 22R's
- Who knows this goop grime crud stuff?
- 1993 2WD clutch replacement w/22re
- 22re exhaust?
- Surging idle when brake pedal is applied
- Necessary seals for 90 4WD Front rotor replacement
- Fuel leak, fuel dampner problem
- headlight short on my new rig??
- Will vacuum leak cause auto trans shift problem?
- Radiator for 95 4runner SR5 RWD
- Timing Belt, VC gasket, etc. for 3vze
- 3vze head fitment question
- Head gasket or timing cover?
- Cold Starter clogged or bad injector
- State of the 22R / 22RE
- 5 Speed Chatter \ Noise
- EGR clogged @ head
- 22RE Deckplate Mod
- 86 22re fuel pump
- Any power gain from a high flow cat/ test pipe?
- Name that engine noise?
- Mounts for grille guard
- EB 268 VS Stock cam shaft
- Coolant Filter Integration?
- over sized valves and cam upgrade
- Got a new set of wheels
- New Yakima roof rack.
- What happens if I don't replace my squeaky control arm bushings?
- Upper Radiator Hose
- 91 22re manual swap W56 to a G54 is it a compatible swap
- Climate Control Cluster 1990 V6
- HOW TO: Remove the Oil Pan on a 22re 4wd
- 88 toy 22re truck 4x4 knock sensor
- Cant find anything on overbore.
- 3.0 engine wont start cranks but no spark
- 91 to 92-95 grille swap
- black out bumper lights?
- Tranny or Engine Problem ????
- Help with brakes
- i need some carb help
- windshield wipers....
- EGR temp sensor resisitor 10K
- Another air injection question
- flexplate question?????
- 22re has slight rattle.
- 3vze idle issues
- does my truck need a new throwout bearing
- Question concerning injector, need advice. 93 4unner 4x4 auto w 120k miles
- '94 2WD Pickup - I Broke a Torsion Bar
- New shoes on the rig with surf pictures..
- New Fj voodoo blue paint job on my truck
- 1/4 throttle has more "umph" than 1/2 or full throttle???
- 3vze hg, putting everything back together, was wondering how important this is? (pic)
- cracked dashpot cover
- 88 runner transmission problem
- 1986 Pickup 2.2 4 banger Loud rattle noise
- Help!!! 1988 2wd very hard to start when warm!!!
- Need Help, Throttle Cable
- 2nd Gen parts?
- rusty camshaft?
- Will shock extensions suffice?
- 22re died - Timing Chain skipped a tooth or headgasket? Maybe both?
- What Driveshaft for This Application?
- will a 92 pickup v6 3rd member fit 22re 3rd member?
- Rig sputters and dies....
- oil burning
- 89 22RE rough idle
- AFM adjust yielded poor results, why?
- 22re problem after washing
- 1989 3.0 High Oil Pressure
- Will (4) 35" tires fit INSIDE of a 2nd gen 4Runner?
- drop tank or lift bed to replace/repair brake line
- Installing aftermarket gauges, how to keep original?
- May Buy an 89 4runner. Need advice for Temp Problems on 3.0
- Upper ball joint castle nut size
- Need help interpreting TPS readings and replacement.
- EFI fuse keeps blowing
- Did EGR removal and WoW
- 1990 sr5 4x4 wont start engine problems
- 2 inch 4crawler body lift with 33s installed pics!!!!!!!!!
- 94 4runner swap front bumper with 92 truck?
- 89-95 Bumper fit
- my runner
- can a 22re tow a small popup camper
- HELP temperature sensor bad?
- Truck broke down AGAIN!!!
- 95 3.0 Problem starting once warm, bogging down on power, runs rough at times
- 1990 4x4 V6 Heater Core Question
- ECT Box on 89 pickup column shift
- motor locked up, any ideas
- Stupid gear question
- Engine wiring
- shakin knockin rockin and not rollin
- crankshaft pully bolt
- Front Lockrite, used it for the first time today
- OEM Gas tank replacement/swap
- What is this plug?
- shift tower problem
- What does this electrical plug extension accomplish
- 4 wheel drive problem
- charging issue on start up
- Power antenna swap
- Another 88 rebuild/questions thread (in Hawaii)
- 3vze won't run after rebuild
- 86 SR5 Ext Cab 2WD Turbo Transmission...
- 91 Runner Driveline??
- 93 pickup hard starting issues
- Opinion... wiring, tranny Bubbafied 4runner
- brake issue pls help
- 1987 Rear window issues
- Finally got my front locker put in.... *phew*
- Engine coolant temp sensor
- 88 22re wont start
- Knock Sensor ????
- front stub shaft removal with a locker in there
- Skid plate search
- Random stalling issue
- 2wd oil pan with SAS
- Start bad in warm weather
- Replaced brakes/rotors...now there's a clacking noise on driver's side...
- timing chain
- trimming upper control arm
- Installed Air/Fuel Ratio Guage on my 4runner
- 22re problems
- Lights out what fuse
- Post your Bumper!
- 22RE Rebuild Check Engine light now
- Wondering about carb interchange.
- Weird Cooling System Problem!! Help!!
- O2 Sensor on Thorley Header
- bypass hose cooling line cracked, replaceable?
- Brakes nightmare
- getting to much fuel?
- Is my clutch toast?
- Cracked head between valves 3vze, need input
- cleaning 22re vacuum rail
- Stock Height Leaf Springs
- Retorquing head bolts on 3.0?
- V-6 rear U joints the same at 4cy??
- tricking 3.0 ecu?
- 92 Runner map light
- Blown Head Gasket!
- Supra AFM Finally Lives;)
- Cold weather CV boots? One brand better than the other?
- Finished valve cover gasket replacement, now idle goes up and down 500 rpms.
- "91 4-runner headlight replacement
- Powersteering question
- Engine Hesitates and chokes in low rpms
- 1984-1989 4Runner (COMPLETE) Driver/Passener Seat Swap DIY (with oodles of photos)
- Ignition control/Ignitor
- Starter issue-another thing to look for
- Automatic Transmission questions
- got a free pickup
- 89 4Runner tailgate window track install question
- Quick question - on the phone with Toyota parts counter
- pulley part number
- Broke my passenger side CV flange!!!
- Help with a mechanical problem- My truck is jerking for some reason!
- 3.0 header install, got an 02 sensor question
- Anything thinking of buying a Warn Rockcrawler bumper?
- Control Arm Bushings - Can you lubricate them?
- Engine tapping under load? 22re
- What 2WD Transmission do I have? Updates on what's gonna happen with my 92 xtra cab
- 86 22r over heating
- Defluting 2nd gen headlights
- T-Case Shaft swap?V6 shaft to 22RE Tcase?
- 22re Header Clarance to the frame and upper control arm
- How long can i let my truck sit?
- cammed 22re help
- 95 toyota 4x4 transmission wiring
- 1987 4runner SR5 Rear Differential Gasket Replacement DIY Guide (with Pics!)
- update on my transmission/input shaft/ buzzing/ whirring sound issue
- 1990 4runner 4x4 roaring in front pass. wheel
- 3.0v rebuild
- My 22RE won't hold between 1200 & 1800rpm???
- cylinder cutout?
- Clutch problems!!!!!!
- Build opinion wanted
- Where can i get a light rail like this one????
- Air Filter Housing Differences
- 91 4wd problems
- Sticky RPM and surging
- stuck speedometer
- Rear window
- What is this [or, more vacuum madness]??
- 3vze injector parts
- Need education on suspension..wobbly as I drive.
- Rough running between 2K-3.1K RPM on highway
- Buzzing/humming/whirring/grinding sound from the depths. A real challenge!
- Noisy VSV - Vacuum leak?
- Swap out your P/S idler pulley with your A/C idler
- Pulling in 4x4
- bad bank 1 miss need help.. going crazy!!!
- Fuel Injector (Green Cap), 3VZE
- 3vze stalling when engine warm and driven for a while
- Bad Tranny? Clutch? Master Cylinder?
- 95 4runner automatic transmission problems....
- Purchase Magnaflow Catalytic Convertor
- Cleaned my battery and my CEL came on
- carb trouble
- HELP serious pull to side in 4 wheel dr
- Radiator Swap
