Cleaned my battery and my CEL came on
Old Feb 22, 2010 | 03:28 PM
4mydogs's Avatar
Question Cleaned my battery and my CEL came on
Yesterday I disconnected my battery to clean the terminals, and today my check engine light came on. Had driven the truck about 20 miles, turned it off and on a couple of times before the light came on. Think there may be a connection, or is it just coincidence?
I hate the check engine light.
Old Feb 22, 2010 | 03:53 PM
DeathCougar's Avatar
Pull the code and figure out what its all about?!
Old Feb 22, 2010 | 04:01 PM
4mydogs's Avatar
Yeah, I know . . . for me that means a trip to the mechanic.
Old Feb 22, 2010 | 04:10 PM
Mountain Cop's Avatar
Or Kragen / O'Reilly's / Schucks and do it yourself. Rental of the machine is a lot cheaper than taking it to a shop.
Old Feb 22, 2010 | 04:11 PM
Tubbyfatty's Avatar
Are you kidding me?
You get a 2-4'' piece of 14ga wire or something like that.
Strip the ends, pop the hood and go to the fuse box, next to it will be a grey box called "diagnostics", put 1 end of the wire in the TE1 port, put the other end in the E1 port.
Go inside your truck, turn the key to "on". Count the flashes. There will be a pause between the 2 numbers. Example: If it flashes 5 times, then pauses and flashes 2. code 52. Then you get on here and look for "code 52" and see what its about.
Old Feb 22, 2010 | 04:13 PM
Huh. Didn't know that works for the V6. Good to know.
Old Feb 22, 2010 | 04:18 PM
Tubbyfatty's Avatar
This isnt a 96+ vehicle, so we have OBD1, not OBD2 (obd - on board diagnostics). The check engine light on these things doesnt really mean alot.
Old Feb 22, 2010 | 04:21 PM
Way too cool. I just didn't know where the cutoff was. That eliminates computer diagnostics on both my 'runners.
Old Feb 22, 2010 | 04:47 PM
Tubbyfatty's Avatar
Yea its nice knowing a piece of wire is your "scan tool" haha.
Old Feb 22, 2010 | 05:18 PM
toyota4x4907's Avatar
or a paper clip....
Old Feb 23, 2010 | 12:13 AM
stormin94's Avatar
x2 on the paper clip. It's easier to fit in the holes of the harness. Pulling the code is pretty much as simple as putting gas in the tank. All you need to be able to do is read, and count, and follow a picture diagram to see exactly where to put the paper clip. I bet some mechanic would love charging $40 to pull the code of an OBD 1 vehicle, charge you an hour for shop time for something that literally takes about 2 minutes.
OBD 1 rocks!!!
Old Feb 23, 2010 | 06:09 AM
hunter4runner's Avatar
so whats the code ?
Old Feb 26, 2010 | 05:46 AM
4mydogs's Avatar
It's a code 71, which I searched and found is the EGR. But after I did this, the light went out. Did I clear the code? The engine is still running fine, so I guess I'll wait and see what happens. Thanks everyone for your help.
Old Feb 26, 2010 | 09:26 AM
abecedarian's Avatar
The code basically means that the EGR valve was activated and the temperature sender on it did not report the proper temperature to the ECU. If it never comes back, there's no problem and I wouldn't worry about it. If it does... could be a few things related to the EGR valve like the valve itself, the temp sender, loose connection or vacuum hose....
Old Feb 26, 2010 | 11:34 AM
4mydogs's Avatar
Thanks for help understanding what it might mean. I wonder what road a mechanic might have taken me down with this code. The engine is running fine, so I'll just keep on keepin' on.
Old Feb 26, 2010 | 04:36 PM
stormin94's Avatar
Lol. I have that darn code 71 too. When I disconnect the battery, it turns off for a little while, but then after about 15 minutes, the CEL is burning bright again.
Old Feb 26, 2010 | 04:39 PM
I fought that dang thing and finally got it or so I thought, and it came back so I gave in and took it out and I am so happy I did. But if you dont want to do that a 10k ohm 1/4 watt resistor is 99¢ for 5 at radio shack
Old Feb 26, 2010 | 04:41 PM
I payed the 185$ and replaced mine and got a new temp sensor and it still came back.
Old Feb 26, 2010 | 04:59 PM
stormin94's Avatar
Hmmm..... $185, or $0.99..... I think I'll take care of that light the first time for $0.99.
jasonty
41
Dec 23, 2018 01:00 PM
256mbaker
Jul 31, 2015 06:45 PM
v_man
Jul 23, 2015 04:01 PM
Sandman
Jul 14, 2015 12:36 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
