Mis fire 96 Tacoma 3.4 4x4
Old Jul 22, 2015 | 06:06 PM
256mbaker's Avatar
cel is on - had it scanned at local parts store - misfire on cylinders 4 and 5 - I took it to a friend of mine who is a very good mechanic he has a better scanner than the parts store - his will retrieve live data - cylinder 4 is mis firing at idle but comes back at 3000 RPMs - cylinder 5 is great at an idle but mis fires at 3000 RPMs - have replaced all 3 coil packs - new plugs " ngk dual electrode and gapped correctly " and new plug wires ---- never seen a mis fire swap cylinders like this -- HELP !!!!!!
Old Jul 23, 2015 | 08:20 AM
vasinvictor's Avatar
Get yourself a FSM. It outlines misfiring diagnostics very well. It includes checking wires from ECU to ignitor and ignitor to coils. A failing crank sensor will cause weird misfires, as will a loose crankshaft pulley.
Old Jul 31, 2015 | 06:45 PM
FeralOffroad's Avatar
Recently had the same exact problem that ended up being a couple $35 fuel injectors and problem solved..
Flying91
45
Apr 11, 2024 04:39 PM
coleypull15
Nov 3, 2015 07:41 AM
94whiterunner
Jul 12, 2015 07:15 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
TokyoD23
Jul 12, 2015 06:01 AM
