Engine tapping under load? 22re
Old Feb 25, 2010 | 07:18 AM
ohyeahcrx's Avatar
So my 1988 truck makes this terrible tapping sound under a load, and its only under a load. I did some searching and found out it could be piston slap (which would get quieter as the engine warms up, but mine doesn't. Also its a newly rebuilt engine with a little over 2,000 miles on it.) Or it could be a bearing issue (rebuilt engine again). Or a faulty PVC. Has anyone else had anything like this? Its only recently developed out of the blue.
Any help thanks.
Old Feb 25, 2010 | 08:59 AM
Firefightertaco's Avatar
So who rebuilt the motor and what all was replaced on it?
Old Feb 25, 2010 | 09:05 AM
84foyota's Avatar
Sounds like you have an exhaust leak between the cylinder head and the manifold. This will make a ticking sound and it's more noticable under throttle and load. Check and replace the gasket if you find it broken.
Old Feb 25, 2010 | 09:44 AM
ohyeahcrx's Avatar
I bought a rebuilt motor from a shop in Phoenix.
Really? I will have to check that out?
Old Feb 25, 2010 | 09:53 AM
did you put the motor in your self?
It might be a exhaust leak, can you make the noise when you just have the truck parked and rev the throttle or does it have to be driving up a hill or something that put a lot of load on the motor?
Old Feb 25, 2010 | 10:28 AM
ohyeahcrx's Avatar
Yes I put the motor in myself. Could be? I just dont want it to be something detrimental to the engine ya know. Its only under a load. If you rev it up, nothing. And its any kind of load not limited to only going uphill.
Old Feb 25, 2010 | 10:47 AM
you might try to tighten your exhaust bolts but be careful cause they can strip out the head pretty easy, and if that doesn't do anything u might wanna go to the shop where u got the motor an talk to them, might sound like they did crappy job rebuilding it
Old Feb 25, 2010 | 10:48 AM
and you did put a new gasket on for exhaust header didn't you?
Old Feb 25, 2010 | 10:55 AM
ohyeahcrx's Avatar
Yeah I dont see why I wouldnt have ha.
smthwsn357
May 1, 2024 07:28 AM
steve miller
Oct 10, 2015 01:40 AM
razorman8669
Jul 12, 2015 12:13 PM
skoti89
Jul 8, 2015 12:05 AM
Nickdigg
Jul 7, 2015 06:04 AM
