Rear window
Old Feb 23, 2010 | 11:31 AM
omar132004's Avatar
Rear window
The rear window on my 1995 toyota 4runner sr5 won't go up or down, when I push the switch, the motor is working but the window doesn't move. Any Sugestions?
Old Feb 23, 2010 | 11:37 AM
xfactor203's Avatar
You prob. already checked, but, window lock?
Old Feb 23, 2010 | 11:40 AM
omar132004's Avatar
Checked the window lock, thats not it, it's bugging the hell out of me, and its a bitch to get to it because the rear pannel comes off and theres not much of a hole to see in there or even work
Old Feb 23, 2010 | 12:04 PM
stormin94's Avatar
It's probably either the switch, or the relay. Check by putting your key in the back lock, and see if it does anything, if it does, It's probalby your switch. Try replacing the switch, and if it still does it, it's your relay. Or just replace both, I'd be willing to bet it's one of those two.
Old Feb 23, 2010 | 12:09 PM
omar132004's Avatar
The key does the same thing. the motor runs but the window doesn't move. where is the relay located?
Old Feb 23, 2010 | 01:04 PM
stormin94's Avatar
My relay was in the driver's side rear panel. Do you hear a click when you try to put the window down? How do you know the motor runs?
Old Feb 23, 2010 | 01:48 PM
omar132004's Avatar
I know the motor is running because i can hear it. The window doesn't go up or down.
Old Feb 23, 2010 | 02:08 PM
tj884Rdlx's Avatar
if the motor is running, but the window is not moving, you've either: broke/lost the bolts that hold the window to the regulator; or sheered the teeth off the gear so its not driving the reg. you'll have to open 'er up and look that the window is still attached. but it sounds like you'll need a new motor. pull one from a driver's door. see refs below. this took 10 secs google searching! good luck.
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
https://www.yotatech.com/forums/f116...or-mod-118097/
4Crawler's Avatar
If the motor is running then either the gear on it is stripped out on the motor shaft or the gear's teeth or the teeth on the mechanism are stripped.
Old Jan 17, 2015 | 01:05 PM
coupstar's Avatar
Similar issue
I came across this while trying to figure out my own rear window problems. I'm not well versed on this so Stormin, I'm hoping you're still watching this thread.
My rear window on my '95 4Runner stopped working a couple of weeks ago and it's gone from minor inconvenience to something I'd like to fix; I've checked the fuses and haven't seen any that are out. The reason I replied to this thread though was that you mentioned hearing a click- I hear a click (when using the key or the switch), but nothing happens, what does that mean?
Thanks!
Old Jan 17, 2015 | 01:10 PM
4Crawler's Avatar
Thanks!
Might mean the relay coil is being energized (i.e. the switch is working), but the relay contacts are dirty or otherwise not making an electrical connection:
- http://www.4crawler.com/4x4/CheapTri...leshootingTips
Old Jan 17, 2015 | 01:19 PM
coupstar's Avatar
What are the chances of that happening with the factory plastic still in place? I know anything is possible, but when I pulled the trim and accessed the panel it was sealed up tight with factory shielding. I didn't want to just dive in with a razor blade to gain access- I just replaced the panel and trim and came to the forums.
It looked pretty clean in there.
Old Jan 18, 2015 | 01:33 AM
wyoming9's Avatar
Red face
It is electrical things wear out.
Old Jan 18, 2015 | 06:09 PM
RAD4Runner's Avatar
Like 4Crawler mentions ^^^
Did you check if you get power to the wires that connect to the motor?
Did you inspect and test the wires in the flex harness that connects between body and tailgate?
Repeated flexing could break the wires in there, so even if the relay clicks to send power to the motor, power does not get to the motor because the wire carrying it is broken. It is no enough to see if insulation is broken or not. Even good insulation may have broken wire inside.
Old Jan 18, 2015 | 06:31 PM
scope103's Avatar
... it was sealed up tight with factory shielding. I didn't want to just dive in with a razor blade to gain access- ..
IF you get to where you need access to the inside of the door, DON'T razor out that plastic. It protects the door from moisture, and you're going to want it back when you're done.
On my driver's side door, the plastic was sealed to the metal frame of the door by something like tar. Heat it gently with a heat gun (or hair dryer) to soften it, then gently pull it back. Be careful; when warm that stuff will stick to anything and everything.
When done, warm it up a little, and carefully press it back.
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
