Rear Window - Rolls down on its own!!
Old Jul 21, 2015 | 06:48 AM
RustBucket's Avatar
Got an interesting puzzle for the schematically inclined...
Drove to work today, keyed off and the back window rolled down on its own.
With IGN off (and window down):
- Rear switch on the gate does not work
- In-cab button does not work (not supposed to anyway)
With IGN on:
- In-cab button operates normally, it will roll the window up and down no problem
I tried pulling the topper bolt that kills the switch, no change.
I tried pressing the window lock button, no change.
Here's my workaround: If I hold the window button UP while IGN is on, and then turn the key off, the window will stay up.
Any ideas?
Thanks
Old Jul 21, 2015 | 09:11 AM
Team420's Avatar
I bet its the switch on the gate causing it...
Old Jul 21, 2015 | 09:15 AM
RAD4Runner's Avatar
Hi Rustbucket,
Rear window lock only affects console switch operation.
How window system works is explained here.
Originally Posted by RustBucket
Drove to work today
(1) Keyed off and the back window rolled down on its own,
(2) With IGN off (and window down): Rear switch on the gate does not work
By no change, you mean window still rolls down when you key off even with topper bolt removed? Tried disconnecting the switch itself? (Location in pic below)
If it still does it... Most likely Reason is Blue and white wire between Pin 11 of relay and pin 2 (down) of tailgate key switch is dangling is shorting to ground somewhere. (L-W, in red rectangle in schematic below). I suggest you trace that wire down. I suspect the flex harness between body and tailgate.
Or Tailgate switch contact intermittent and switch is mechanically stuck in down position where a little shake or movement makes intermittent contact in down direction.
https://www.yotatech.com/members/rad...120819-013.jpg
hmmmm... sounds like coincidence
Old Jul 21, 2015 | 09:55 AM
wyoming9's Avatar
Red face
Electrical Demons most often found in power plants .
A young one may have been chased out!!
Been getting a lot of rain up there??
I am thinking it has to be in the window relay
If the cover Top Safety is open The motor circuit should not be able to complete.
Thinking this over Demons are still my first choice!!
Only left is break out The Homer and do some trouble shooting
Old Jul 21, 2015 | 12:29 PM
RAD4Runner's Avatar
LOL!
Disaster response team coming...
Old Jul 21, 2015 | 01:21 PM
ThorInc's Avatar
Demonic possession.......I will now go back into seclusion.
Old Jul 21, 2015 | 02:14 PM
RAD4Runner's Avatar
My name Is Lucifer... Pls take my hand, oh yeah.
Old Jul 21, 2015 | 06:37 PM
RustBucket's Avatar
Well that got a little weird
So now the workaround doesn't work no more. Window is down and there ain't no getting it back up.
RAD, I'll check the wire you indicated first opportunity. I do appreciate the helpful tips and personalized schematic!
Old Jul 21, 2015 | 09:40 PM
RAD4Runner's Avatar
Most welcome.
Like I thought, the workaround sounded like a coincidence.
The console switch still works, right?
Now that it won't go back up either, I would also suspect the pins 10 and 11 section (tailgate switch) of the relay module. Basically:
(1) inspect all wires that go between that and the tailgate switch,
(2) The wire that goes from tailgate switch center contact back to top off switch,
(3) test pins 10 and 11 according to my rear "Window Control" post
(4) inspect relay and surrounding for moisture. Water could get in through the quarter vents if slats are worn out. I have a post on replacing the slats, too.
Old Jul 21, 2015 | 10:43 PM
wyoming9's Avatar
Red face
I have seen all different kinds of failures but never one where things go down by themselves.
So now the window is down for good??
Will not go back up if it is not inside jumper the motor to get it up.
Old Jul 22, 2015 | 06:59 PM
RustBucket's Avatar
Blue/white wire was the culprit. It was causing the motor to just run all the time -- it was hot too!
Thanks for the help guys.
Old Jul 22, 2015 | 07:17 PM
dropzone's Avatar
Fossilized
Was it shorting or?
Old Jul 22, 2015 | 11:45 PM
RAD4Runner's Avatar
Probably shorting to ground. That should run to one pin of the tail gate switch.
Old Jul 23, 2015 | 05:04 AM
RustBucket's Avatar
Yes, the wire coating was abraded through in 2 locations.
Old Jul 24, 2015 | 04:46 AM
RAD4Runner's Avatar
Cool you found it. Now I would trace it and the other 2 wires all the way to the tailgate switch to make sure that they are connected properly.
jasonty
41
Dec 23, 2018 01:00 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
DrZero
18
Jul 24, 2015 11:31 PM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
