Rear Window - Rolls down on its own!!
Got an interesting puzzle for the schematically inclined...
Drove to work today, keyed off and the back window rolled down on its own. With IGN off (and window down): - Rear switch on the gate does not work - In-cab button does not work (not supposed to anyway) With IGN on: - In-cab button operates normally, it will roll the window up and down no problem I tried pulling the topper bolt that kills the switch, no change. I tried pressing the window lock button, no change. Here's my workaround: If I hold the window button UP while IGN is on, and then turn the key off, the window will stay up. Any ideas? Thanks |
I bet its the switch on the gate causing it...
1 Attachment(s)
Hi Rustbucket,
Rear window lock only affects console switch operation. How window system works is explained here.
Originally Posted by RustBucket
(Post 52281698)
Drove to work today
(1) Keyed off and the back window rolled down on its own, (2) With IGN off (and window down): Rear switch on the gate does not work I tried pulling the topper bolt that kills the switch, no change. If it still does it... Most likely Reason is Blue and white wire between Pin 11 of relay and pin 2 (down) of tailgate key switch is dangling is shorting to ground somewhere. (L-W, in red rectangle in schematic below). I suggest you trace that wire down. I suspect the flex harness between body and tailgate. Or Tailgate switch contact intermittent and switch is mechanically stuck in down position where a little shake or movement makes intermittent contact in down direction. Attachment 119405 https://www.yotatech.com/members/rad...120819-013.jpg https://cimg9.ibsrv.net/gimg/www.yot...7b41308613.jpg Here's my workaround: If I hold the window button UP while IGN is on, and then turn the key off, the window will stay up. |
Electrical Demons most often found in power plants .
A young one may have been chased out!! Been getting a lot of rain up there?? I am thinking it has to be in the window relay If the cover Top Safety is open The motor circuit should not be able to complete. Thinking this over Demons are still my first choice!! Only left is break out The Homer and do some trouble shooting |
1 Attachment(s)
Originally Posted by wyoming9
(Post 52281726)
Disaster response team coming... Attachment 119402 |
Demonic possession.......I will now go back into seclusion.
My name Is Lucifer... Pls take my hand, oh yeah. :)
Well that got a little weird :)
So now the workaround doesn't work no more. Window is down and there ain't no getting it back up. RAD, I'll check the wire you indicated first opportunity. I do appreciate the helpful tips and personalized schematic! |
Most welcome.
(Post 52281822)
So now the workaround doesn't work no more. Window is down and there ain't no getting it back up. The console switch still works, right? Now that it won't go back up either, I would also suspect the pins 10 and 11 section (tailgate switch) of the relay module. Basically: (1) inspect all wires that go between that and the tailgate switch, (2) The wire that goes from tailgate switch center contact back to top off switch, (3) test pins 10 and 11 according to my rear "Window Control" post (4) inspect relay and surrounding for moisture. Water could get in through the quarter vents if slats are worn out. I have a post on replacing the slats, too. :) |
I have seen all different kinds of failures but never one where things go down by themselves.
So now the window is down for good?? Will not go back up if it is not inside jumper the motor to get it up. |
Blue/white wire was the culprit. It was causing the motor to just run all the time -- it was hot too!
Thanks for the help guys. |
Was it shorting or?
Probably shorting to ground. That should run to one pin of the tail gate switch.
Yes, the wire coating was abraded through in 2 locations.
(Post 52281975)
