oil pressure
Old Mar 7, 2010 | 06:18 PM
joeboosyota's Avatar
oil pressure
i changed my oil filter about 2 weeks after putting new oil in because of loss of filter wrench but drivng to car wash the gauge was really high never seen it that high. So i wash it off and started it up to leave and the gauges was barely reading at all. could it just be the sending unit or a serious problem
Old Mar 7, 2010 | 06:45 PM
myyota's Avatar
A sending unit can go bad at any time, i would try changing it first. If you drove it home and didn`t have any problems then it should be ok. I did have the oil pump go bad on my 86 4Runner, and i was lucky enough to catch it before it did any damage.
Old Mar 8, 2010 | 07:40 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Hot OP can look like it's not even reading... But a quick reference to THE OWNERS MANUAL and noticing if it's in the NORMAL ranges will, or should put yer fears to rest...
Anything not in normal is a cause for concern... But your light should come as well..
Old Mar 10, 2010 | 05:52 PM
i used a manual oil pressure tester and at hot idle it was at 25 psi and at 3000 rpms it was about 70 psi i think that thats about right. what do you think probaly the oil pressure sending unit?
Old Mar 10, 2010 | 08:31 PM
weaselman's Avatar
yes. either your sender unit is bad. or your gauge in the dash is bad. you have great pressure.
Old Mar 14, 2010 | 04:39 PM
thanks every one.
Old Mar 14, 2010 | 04:42 PM
camo31_10.50's Avatar
damn..i run like..15 at idle..and about 50 at 3000rpms... =(
gonna change my oil..maybe switch back to 20w50
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
