Engine wiring
Old Feb 28, 2010 | 01:20 PM
808Yodi's Avatar
Exclamation no need to read *found it*
Did a timing and cover job. Engine cranks and won't fire.
Unscrewed the gas bolt to EFI and shot gasoline all over...fuel pump,etc. works.
Sparks should be fine.
I checked around the engine and forgot to rebolt this**
not sure where it goes. I don't know if it's just a ground -- it has at least 2 or 3 wires going onto its two prongs (rectangular metal plate with circular opening.
here's the pics --
it's raining crazy up here in the JUNGLE so if i get this running i'm going mudding and rambling @ Jaws.
I'll put up some pics if it goes down so ya'll can see the famous PEAHI and JAWS hawaii scene
thanks fellas
this is the wiring harness:
this is the wire:
Old Feb 28, 2010 | 02:01 PM
myyota's Avatar
That looks like the ground wire that bolts to the intake. So did you replace the timming chain and cover ?, if so, you had to remove the distributor, so i bet its out of time.
Old Feb 28, 2010 | 02:06 PM
808Yodi's Avatar
The fuel intake -- just to make sure...it's the bolt that when you've got pressure and gas...unbolting shoots gas out...
Old Feb 28, 2010 | 02:51 PM
808Yodi's Avatar
https://www.yotatech.com/forums/f116...-guide-194413/
found it...I need to start thinking more
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
steve miller
Oct 10, 2015 01:40 AM
toyota32
Jul 6, 2015 05:42 PM
