Another air injection question
Old Mar 3, 2010 | 11:03 AM
diablo's Avatar
I have a 89 truck with a 22rec, I have a header that blocks off the air injection tube. My question is with the tube not connected and the hose off of the air filter box and blocked what if anything will this do to performance and what effect will it have on the egr if any? thanks Diablo
Old Mar 3, 2010 | 04:51 PM
MudHippy's Avatar
It's going to slightly lower the exhaust gas temps and stop sucking air from the intake.
Theoretically both can be a "good thing" performance wise.
It may also cause the catalytic convertor to become less efficient.
It'll have absolutely NO EFFECT on the EGR, however, for good or bad.
Your welcome!
Old Mar 3, 2010 | 06:19 PM
diablo's Avatar
thank you mudhippy, do you think the slight drop in temp will offset the rise due to no egr, just kidding thanks
Old Mar 5, 2010 | 02:21 PM
MudHippy's Avatar
Ya lost me there. Perhaps intentionally...?
If you have no egr, that shouldn't cause any significant rise in exhaust gas temp(at least probably not enough to compensate for deleting the pulsed secondary-air injection system). You didn't mention that you had no egr however. In fact I thought you were saying that you did have an egr.
If no egr...then no effect, right?
Old Mar 5, 2010 | 02:37 PM
diablo's Avatar
mudhippy , Idid fail to say that the egr is clogged sorry for loosing ya
Old Mar 5, 2010 | 02:47 PM
MudHippy's Avatar
No problem...on the same page then!
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
Avenged
Jul 9, 2015 07:55 AM
