- GM CS 144 upgrade... CHARGING ISSUES !HELP!
- CSI useless??
- 4 runner+hilux how to link
- power window regulators...Where?
- Cruise control diagnosis - 87 4runner
- Yet another 22R noise thread
- Best Exhaust for 3VZ-E
- replaced ground wire connector = more power
- throttle body
- 22RE TPS IDL-E2 value question
- 3.0 starting issue
- 87 22R overheating issue!!!!
- Help with gasket identification
- Auxilary Air Valve question?
- 3VZE MAIN BEARING CAP RETARDEDNESS please advise!!??
- Throttle body rebuild
- Vacuum question? (pic.)
- 22re won't start hot
- 1993 4runner 22re over charging!
- 86-95 OEM 4.88 gears: were they also LSD?
- 88 22re misfire when wet
- new truck no start
- What is the long vacuum tree called and where to get one?
- 88' 3VZE Cranks no start
- 89 22RE Surging idle on warm-up
- Turbo project, COMPLETED!!!
- Cruise Control driving me nuts!
- Transmission/T-Case leak at tranny mount
- When to replace fuel pump 94 4Runner 3VZE
- Rcv cv axles
- steering column question.
- New 3VZE Long block advance timing issues?
- started the rebuid yesterday
- Idle issues and cam plugs
- 92 3.0 pickup...will start, then ticks and dies
- fuel tank swap- questions
- New 88 Pup owner. Tuneup and other questions.
- Rough idle start up (yes,I've searched many threads)
- Sluggish 94 toyota pick up
- What spring rate on KING springs for a long travel setup
- Clutch question 91 motor/87 W56
- 22re oxygen sensors
- 4 runner fender flares
- stick in h3 bulb into clear signal housing
- 134K miles still original set of rear brakes...
- Tranny Problem
- in 3 ft of water????
- Transmission removal question
- Center Belt Buckle - 60/40 Bench in a 93 Xtracab - How does it work?
- aal on my 88
- 88 yota not running right
- 86 toyota truck front suspension
- Serial Number Question...
- Cheap Way to extend fenders?
- Gangster lean, '92 4unner
- '94 door lock/latch problem
- Oil coming out of throttle body.... Help!
- g58 tranny going out completly??
- Part info?
- 93 toyota headlight issue
- Patch Panels
- CT20 Turbo blows oil
- Another:"what part is this/purpose"? (pic)
- Senior smashed into my 4runner!!
- Smoking 22re, Good compression test results any thoughts?
- 3vze Ignition timing and timing belt issue
- Tundra BRAKE upgrade to 2 Gen 4Runner
- 22RE O2 Sensors
- stuck birfield?
- Hate my mirrors!
- What part is this called?
- Seat swap time !!
- Heater not working so good
- 4RUNNER rough start up.. Grinding noise, Bog down, hesitation, freeway deceleration
- Coil and igniter wiring help
- carb'ed 86 toy pick-up fuel line
- FJ80/LC coils?
- All on the fritz: turn signals, temp gauge, fuel gauge, idiot lights
- exhaust 3.0
- EGR System Blocked from Factory?
- '92 runner 4x4 murderess flute noise in the engine?
- Need advice on Steel Seal4 shrt term/temp fix(sry so long,full details incl)
- 4Runner won't start
- running a 22re (non carb) on propane
- 86 toy is dead
- Replacing Coolant
- plasma clocks
- Spark Plugs for 22R-E
- Help me identify these unplugged thingys please!
- 87 fuel guage help!
- 90 4Runner 4wd issue..
- blowby after h/g replacement?
- Help with getting parts together for head gasket job
- 1991 TOYOTA SR5 trailer lights Wiring advise?
- 1991 4x4 Truck and Needle-Bearing Conversion
- Philadelphia Toyota Guru
- airbrushing the mighty lux
- Acceleration issue found...
- SR5 instrument cluster differences
- my 3vze engine sound bad
- Blown 3VZE head gasket but have to leave town
- plasma boost gauge :)
- 86 4Runner having trouble starting
- Check engine light
- Flopped!!!
- Having brake issues!
- 22re engblder street sv head and 261c crawler cam
- Intake Manifold Upgrade
- Power Question
- put in leds in the dash now battery light stays on
- 3.0 rough idle
- Engine bogs down
- vaccuum leak/fuel delivery problems
- New Radiator, install help
- TPS fixed but still can't accelerate...22r-e
- Fixed a stripped bolt on the intake, do I need to replace the just-torqued gasket?
- 91 4runner heat problems
- Wheel Bearing, Bushings?
- Got some new shoes (33X10.5'' km2)
- Temp Gauge gone Crazy
- reverse light switch
- 22re wont rev past 5,500rpm, weak, poor mileage after rebuild.
- 89 pickup 3.0 missfiring
- just bought a 1987 factory turbo ex-cab 5sp 4x4!!
- how do i check to see if a 3.0 v6 ecu is any good?
- Is it my cold start injector time switch?
- 22re experts please help me with my DD!! Will not idle
- weather strip for removable top
- High Idle on Cold Startup 3VZ-E
- Debris Found During Oil Change
- loose wrist pin! knock?
- Transfer Case Won't Go Into 2WD
- Weird Clucth Issue, Slips then Grips?
- Gas not getting to Engine
- 3VZE camshaft bearing bolt stripped
- Water temp not working after SR5 Cluster swap
- smitty built rear bumper?
- pacesetter full exhaust review
- Please help me figure out this oil leak (photos and facts inside)
- Jacobs MileageMaster Hookup
- Leaking Injector o-rings
- timing and distributer on 3vze
- smog in california
- no fuel in #1 after valve cover gasket replacement! help!!!
- Blower Fan Stuck On
- home brew 3.0 snorkel w/pics
- Stainless idle screw upgrade
- 22RE Noise
- 22re back two cylinders malfunctioning
- Timing belt and water pump ?
- auto throttle/kickdown cable too short?!
- Advance Auto Speedometer Cable- Close but not quite...
- Engine Diag, dies just after start
- Engine code 71 after installing LCE header
- Antifreeze pouring out of overflow hose
- What does SR5 stand for?
- need creative transmission flush idea
- No front brakes
- 90 4runner code 52 with a knock that sometimes goes away...
- No Spark 3vze
- Help!!!! Clutch Problems!!!
- Problem with diff drop!
- Filling Small Imperfections in the Block (H/G job)
- 89 Standard cab SR5 suspension squeeking
- 22r rod orientation question
- To torque or not to re torque a 22re
- Signs point to head gasket? 87 22re
- Axle Oil Seal
- 88 4runner v6 exhaust.
- Lower control arm - no more adjustment?
- Autozone clutch? Marlin clutch?
- 87 lift kits, anything bigger than 4?
- Noob / Header ? / New Alt info
- Yota's in Cold weather
- 92 3.0 HG diagnosis, questions (and replacement?) thread
- single cab body lift on x- cab
- 88 4Runner No Charge/Battery light on start-up?
- My dash is in the christmas spirit PLEASE HELP!!
- Code 31 air flow meter/circuit
- blow out, now lights don't work and battery will not stay charged
- Gage cluster not working
- Smoke in rad hoses
- Repairing rear brake hard lines?
- loping idle
- ARB IPF H4 Rectangular Headlight Insert (820H)
- rust repair .... help ???
- an 83 22r header on a 86 22r
- Check engine light comes on after being deleted, before even starting
- Motor mount torque specs (22re)
- Odd Power steering leak
- Doing H/G, is this exhaust manifold too rusted to go back on?
- 2'' Body lift installed
- 22re Cold weather bad mileage + low power (no snow or 4x4)
- Spun Distributor Gear
- 93 truck 3.0 efi hesitates to a stall when hot
- 87 PU charging problem
- pulling a 22r head
- 93 4Runner, hesitates, white smoke when cold
- Heater core Oring size
- 3.0 missing,poor idle,strong exhaust smell
- Truck bed and fuel tank interchangability question
- 22RE Cam, Springs, Rockers affecting.....
- I think my HG is gone..help?
- Unknown Wiring harness conector?
- Clutch issue
- TPS adjustment now can't accelerate...
- Clutch Release
- What's this in my front diff?
- 88 4Runner Rear Widow Defroster Wiring Help
- gear oil
- could a bad lockup solenoid be unoticable and cause bad gas mileage?
- quick 4cyl 8" carrier swap question
- 22RE upper end questions
- My truck shimmies at 60-65 mph
- Head gasket help 95 22re
- How high do you rev your 3vze :D
- '86 4Runner automatic shifts WAY too early
- New clutch seems loose
- Sagging Rear Suspension and LSPV Adjustment
- What should I use to clean my head/block?
- 22-RE Mystery Connector
- 4runner body swap!!!!!
- Temp Gauge issues
- How to unbolt the EGR?
- How do I make the AFM into a circle pipe?
- Camshaft Oil Seals Direction
- 22re oil light conundrum
- 91 Pickup 3VZE overheats
- 22re, oil cooler, and other benefits?
- will corner lights for a 89-91 pickup fit on a 93?
- 94 4runner tailgate swap...92 on 94 ??
- 3VZ-E Metal Head Gasket Source
- Power Steering
- Does your ecu wire harness route through the intake manifold?
- anti-wrap half leaf
- A340H Tranny Swap - Differences between years?
- Stolen Catalytic converter
- Oil Pump- To replace or not? 89' 3.0, 200k miles
- 89 4runner V6 Head Removal Trick- Time Saver!
- Trouble with 87 Toyota
- 1992 Pickup TC Long Travel questions
- 1990 22re P/U no timeing chain marks
- 22RE ESA/Timing issue
- Help a/c owner hilux 1989
- ADD Differential Tube
- Replacing fuel sending unit
- Max Tire size with BushWacker Cut out Flares
- 92 22RE 4x4 5sp - Timing, HG, Clutch. (planned for January)
- Cold Start Injector Time Switch Delete
- bj spacers and a one inch torsion bar crank with 1 inch diff drop
