No Spark 3vze
Old Dec 10, 2010 | 10:56 AM
chad967's Avatar
No Spark 3vze
Hi I have a 1993 sr5 that I'm doing the HG on (basically finished). She isn't getting any amps to the 30A ignition fuse (on either side), I was able to get it started by running a wire from the battery to it. Any idea whats wrong? Is there a fuse box on the inside of the car I should check out?
Also I was wondering if anyone knew exactly what is plugged on the passanger side if the top peice of the intake manifold and which one the PCV hose went to? (the pelnum I think its called?)
Old Dec 10, 2010 | 12:59 PM
scope103's Avatar
The 30amp ignition fuse connects directly to the battery.
So far as I know, none of the ports on the passenger side of the plenum (upper intake manifold) are plugged. Perhaps this will help:
MadMax48
Mar 3, 2020 10:33 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
EatChipsNow
Sep 9, 2015 01:25 AM
