TPS adjustment now can't accelerate...
So, I was having some issues with adjusting my timing. I was not able to set the base timing and when I unshorted the proper diagnostic terminals the ignition did not advance as it is supposed to. So, I posted the issue on here and was given some good advice regarding the TPS being the cause. Sure enough the FSM backed that up and I made an attempt at adjusting it.
After adjusting it I was able to set the base ignition timing and have it properly advance once the shorted terminals were removed. HOWEVER, now my truck (22R-E, 87) can't accelerate! When I hold the throttle open it does not increase the RPMs much if any. Instead it has a delay and sounds like it is taking a break from running... What did I do or what does this sound like? Could it be the TPS needs to be changed or is it something else? Thanks
The TPS must be adjusted within a few thousanths of an inch. I recently replaced the TPS on a 3.0 and 2 thou made a huge difference. The TPS is the same for both.
You probably already did that, but I was suprised at how sensitive it is.
zytra
Jan 24, 2019 03:16 PM
