an 83 22r header on a 86 22r
Old Dec 8, 2010 | 01:01 PM
86yota2wd's Avatar
Since my truck has been totaled and i've been looking for parts i found a guy locally selling a header for an 83 22r and i was wondering if it would work on my 86 22r and what the differences are? also its a manual and mine is an auto i know that these don't work but i am willing to do a little work to get it to fit
thanks!!!!
Old Dec 8, 2010 | 01:36 PM
Elton's Avatar
just make sure the exhaust ports are the same
Old Dec 8, 2010 | 01:39 PM
86yota2wd's Avatar
i was doing some research and the 83 head has round exhaust ports and the 86 has pear shaped... so in theory it should work right?? or no?
Old Dec 8, 2010 | 01:42 PM
Elton's Avatar
ya i dont think it would work
Old Dec 8, 2010 | 01:51 PM
86yota2wd's Avatar
dang he is only asking like 50 and it looked pretty nice... oh well it sounds like i'll just keep the stock manifold
Old Dec 8, 2010 | 01:52 PM
peow130's Avatar
Wont work. But if you have the time, you can just make a new flange out of some 1/4inch steel and weld it onto the existing header tubes.
All youd need is a gasket, a die grinder, and some time.
Old Dec 8, 2010 | 02:04 PM
xxxtreme22r's Avatar
heh, If I were gonna go through all that trouble i would just make my own.
Old Dec 9, 2010 | 04:32 PM
peow130's Avatar
Lol well, the header tubes are the same throughout the years, so to buy the scrap steel, a used header, and a gasket.. you're ahead of the game haha
Old Dec 9, 2010 | 04:33 PM
muddpigg's Avatar
it'll work, OEM gasket will not work.
Old Dec 9, 2010 | 04:39 PM
peow130's Avatar
See other thread:
To put the smaller flange onto the head will only bottleneck the header.. meaning no gains whatsoever.
Old Dec 9, 2010 | 04:43 PM
muddpigg's Avatar
See other thread:
I could look at someone else's post or go drive my truck. There's a difference. For $50 bucks it'll be worth it. Run 2.25" or 2.50" pipe out the rear with a low restriction/high flow cat and performance muffler. You'll enjoy it.
Old Dec 9, 2010 | 04:47 PM
peow130's Avatar
And i can go bolt on some headers onto my V8 car and notice no noticeable gains because the header ports don't match the exhaust ports.
Why do you think people buy headers?
Because they make your engine flow better.
Well, the stock manifold has (you guessed it) pear shaped ports. Why do you think this is true? Well, if they were circular, then you'd see a big fat bottleneck of exhaust gases..
Sort of like dropping your exhaust tubing down to 1".
Old Dec 9, 2010 | 05:06 PM
muddpigg's Avatar
I really am not trying to argue with you but you really don't know what your talking about. So you can be another guy that imagines he knows it all because he has an IQ higher than a toaster (like the rest of us) or you can research it more even try for yourself. Do a poll. I'm sure LCE or DOA might have some dyno numbers to compare.
Old Dec 9, 2010 | 05:12 PM
peow noone makes a specific pear shaped exhaust ports on their headers. noone.
The manufactures use extra holes in the header flange that allows for the post 85 pair tubes to bolt up and accept the pair system though the pear shape.
all the pear shape is for is the pair tubes. the pre 86's had a different way the pair system works though the head which resulted in round holes.
so in short Pear = P.A.I.R.
now if your willing to delete your pair system then any 20/22r header will fit the 20/22r heads. 79-95. Otherwise you have to use year specific headers. Or drill your own P.A.I.R. Tube holes.
Easy way to test this theory is to look at the NWOR site.
http://www.northwestoffroad.com/parts/20-22header.html
1979-95 Header System non-emission version N31001
1979-83 Header System (Type A)* with smog equipment fittings, O2 sensor and hot air pick-up N31002
1984-85 Header System (Type B)* with smog equipment fittings, O2 sensor and hot air pick-up N31003
1984-85 Header System (EFI) with O2 sensor only N31004
1986-87 Header System (Type B)* with smog equipment fittings, O2 sensor and hot air pick-up N31005
1986-87 Header System (EFI) with O2 sensor only N31006
1988-95 Header System (EFI)* (Type B)* with smog equipment fittings, O2 sensor and hot air pick-up N31010
What do they mean by smog (emissions) equipment fittings ? P.A.I.R. Tubes.
end of story, still think it won't work, contact NWOR and tell them they are full of crap.
oh and you can also tell LCE that their PAIR block off plates bottle neck the exhaust system too.
Old Dec 9, 2010 | 05:48 PM
86yota2wd's Avatar
so i read another thread that just popped up about a 22r header on a 22re and the header has the round ports but the heads have the pear shaped ones.. but this is only for the pair system that is used for emissions stuff? so i could but the block off plates from lc and run this header? i'm just curious if it will still bolt up? and if so where do i get the good gasket
Old Dec 9, 2010 | 05:52 PM
it will bolt up, use the block off plate kit from LCE to delete the PAIR system piping (not sure what else to do to delete it at the moment.) Use a header gasket meant for a 20R. That's how LCE sells their headers. It's the same header 81-95 they just supply a different header gasket.
For those who don't believe me read the LCE site. Make note what it says the kit includes.
Remember though it has to be the 4wd and not a 2wd header. The tubes are different between the two.
Old Dec 9, 2010 | 05:54 PM
86yota2wd's Avatar
well i actually have a 2wd. so i need to make sure it is a 2wd then... what are the differences between the two then?
Old Dec 9, 2010 | 05:58 PM
that I could not answer.
Old Dec 9, 2010 | 10:08 PM
Numbchux's Avatar
I have an old Downey header for a 22R that I was going to put on my 4runner. I'm no expert, but it looked to line up to the '86 motor that was in there, but one of the primaries would not clear the UCA. So you might have to worry about that....
Old Dec 9, 2010 | 10:21 PM
camo31_10.50's Avatar
yes it will bolt up fine.
and guys, we're talking about a 4cyl with ~100HP...................even if the round header ports did create weird flow with the pear shaped exhaust ports....we're talking a VERY EXTREMELY SMALL amount of power loss...not even 1HP.....
it'd be different if it was pure race motor, matching ports helps there, but for a 22R.....nah it won't hurt enough to even notice on a Dyno i bet.
TheBFA
Feb 15, 2020 06:55 AM
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
