Smoke in rad hoses
Old Dec 8, 2010 | 03:28 PM
Cptchunky's Avatar
Smoke in rad hoses
So noticed some smoke/steam coming off the motor and noticed it was coming from inside the Radiator hoses. Anyone seen this before or know whats going on? 1988 4wd 3.0 truck
Old Dec 8, 2010 | 06:13 PM
waynesworld's Avatar
seems like u need 2 put sum antifreeze in it?
Old Dec 8, 2010 | 06:41 PM
Cptchunky's Avatar
really?! i need to put anti freeze? lol jk I have anti freeze in it but smoke/steam is still coming out
Old Dec 8, 2010 | 06:51 PM
nv4runner's Avatar
Is it coming out of the overflow bottle or are you actually looking inside the hoses?
In either case that is not a good thing. You're either low on coolant, or might have a leak in the system (either internal or external).
Old Dec 8, 2010 | 07:44 PM
iamsuperbleeder's Avatar
wait, backup...
inside the radiator hose?
I'm thinking "inside the hose" is not the wording you're looking for...
maybe, steam coming from a certain point around the hoses, or one hose in particular?
definitely sounds like you have a leak, thus the steam from the hot antifreeze escaping. when's the last time you replaced the hoses? if never, and you've got a leak, now's a good time to go through them ALL and replace every radiator hose to prevent future leaks and possible breakdowns
Old Dec 8, 2010 | 08:04 PM
Moonfish's Avatar
I'd watch the oil real close and compression test it.
Old Dec 8, 2010 | 08:25 PM
Cptchunky's Avatar
Its coming from around the hoses so I took a few off and the steam or smoke was actually coming out the hose once I took it off to look in it
Never placed the hoses and the bottom and top are a little soft
I have been keeping an eye on the oil just in case nothing odd there yet but I will have to go pick up a compression tester to check that out whats the normal psi for the 3.0?
Old Dec 9, 2010 | 04:38 AM
RustBucket's Avatar
Especially now that it's cold, hot coolant will make lots of steam or "smoke" when it comes out. I popped open my radiator cap when it was still partly hot yesterday and it made alot of steam in the dry, 35F weather.
Old Dec 9, 2010 | 05:45 PM
Moonfish's Avatar
I just realized I don't understand how you have the hose off, it should be full of flowing antifreeze when the truck is running. From what I understand, even a bubble in the system can mess up the flow.
Anyway, it isn't quite clear what you're doin at this point so your answers might not be that good.
Cheap compression testers are known to be not calibrated very well. You end up looking for consistency. The number doesn't matter so much as long as they're pretty even.
Old Dec 9, 2010 | 10:59 PM
Cptchunky's Avatar
Ah my bad I should have made this more clear. It was AFTER the truck was running and I had shut it off
LotOMiles
Sep 14, 2015 11:45 PM
noahstancik
Sep 10, 2015 10:47 AM
--Oz--
Sep 6, 2015 01:06 AM
joeynational
Sep 5, 2015 01:54 PM
128keaton
Sep 3, 2015 05:09 PM
