87 fuel guage help!
Old Dec 16, 2010 | 11:23 AM
DeathSycthe02's Avatar
87 fuel guage help!
My fuel gauge only works when its full. It only moves when you get down to 1/4 of a tank left. What do i need to fix so my gauge actually works. Right now its sucks because i never no how much gas i have until im almost out.... plz help guys.
Old Dec 16, 2010 | 02:19 PM
Bump!
Old Dec 16, 2010 | 02:47 PM
diablo's Avatar
My gauge only worked when full, then after 80miles it would go to empty. It turns out it was the sending unit in the tank. $101.04 at the dealer pretty easy to put in.
Old Dec 16, 2010 | 03:10 PM
sam333's Avatar
Sounds like the upper 3/4 of the wiper( movment) in your sender are shorted. I dont know the specs for the sender ( ohms), but you can pull it and test it. Its probably your sender like diablo said, but you can check the gauge first. just in case. If you can find the specs for the sender you can put resistors ( matching the readings for empty ,half and full) in series with the gauge( inbetween the gauge and tank) and ground them,and that will tell you if the gauge is ok. You could also check the resistance between the gauge and ground( through the sender) when the tank is full and empty and use that for your high and low resistor choice.
Or you could just go buy a new one! ha ha
Old Dec 17, 2010 | 06:57 AM
diablo's Avatar
If you do drop the tank to replace the sender, unbolt the drive shaft at the rear and wire it out of the way, then dont undo the filler and breather at the tank just unscrew the 3 screws at the gas cap it makes its alot easier to drop and put back in, takes about 4 hours. I would spray everything down with PB blaster or the like a couple of times before tear down. It sure is nice having a gauge that works mine was out for 4 years
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
