22-RE Mystery Connector
Old Dec 6, 2010 | 05:42 AM
tankyota's Avatar
Hi guys... longtime reader, first time poster.
I have a 1994 Pickup, 22-RE. I was getting down to the fuel injectors to have them cleaned and I noticed that this plug is just dangling there unconnected to anything! At first I was thrilled, as I thought it was an unplugged fuel injector, which would explain my less-than-great mileage and low power. But unfortunately it wasn't that.
I attached a picture of it. If someone could go out and look at their truck, I would be so grateful! It is the same connector type as the one plugged into the top sensor in the pic, and it's in the same wire bundle too.
HALP! thanks
Old Dec 6, 2010 | 06:19 AM
diablo's Avatar
I also have that same mystery plug on a 22rec, never found out what it went to?
Old Dec 6, 2010 | 07:49 AM
snobdds's Avatar
Do you have AC?
Old Dec 6, 2010 | 10:48 AM
tankyota's Avatar
No, I don't. Could that be it? Doesn't seem like anything A/C related could be by the air intake because (I'm guessing here, like I said, I don't have it) I'd think it would all be mounted over the drive belt. As you can see in the pic, that cable doesn't reach very far.
Old Dec 6, 2010 | 10:51 AM
mightymouse's Avatar
it's for the ac idle up and since you don't have it it isn't plugged in. Don't worry about it i had mine for 10 years and had the exact same plug unplugged the whole time. It took for ever to figure out what it was until i saw one plugged in at a salvage yard.
Old Dec 6, 2010 | 10:53 AM
tankyota's Avatar
Awesome, thanks everyone! I can sleep easy.
Old Dec 7, 2010 | 07:49 PM
snobdds's Avatar
Yep, Air conditioning VSV. Mine is the same way, it is unplugged.
Old Dec 8, 2010 | 04:57 AM
Paperthinedge's Avatar
Unhappy 22RE Timing chain woe's, please help!!!
Ok so I decided to do my own timing chain job cuz it was starting to rub on the engine, making that very noticeable noise. Open it up, low and behold the guide on the driver side is completely destroyed, way to much slack on the chain, and tensioner wore to thin to be useful, so I replaced all that, making sure that it was at TDC during the procedure, threw it all together, took a gander at the timing, and fired it up...... it runs fine for like 1.5 seconds, and bogs down to a stall within 2 seconds, everyone I know is stumped, and if we advance or retard the distributor, or its cap, it will die faster than the position I left it on, also when it first starts its at a constant 12 BTDC but then when it bogs down it get irratic from 10BTDC - 0 TDC, please any help is appreciated! I need to get to work too!
Old Dec 8, 2010 | 05:40 AM
RustBucket's Avatar
Might want to start a new thread if you want any attention to your problem, or better yet search through the numerous timing chain threads that have been thoroughly documented here.
Old Dec 8, 2010 | 05:43 AM
I just joined, I dont know how to make a new thread, or that I even can because I am so new, but I have a legit problem.....
Old Dec 8, 2010 | 07:54 AM
tankyota's Avatar
You definitely can, this thread that I started was my first post. Navigate to the area of the forum you'd like to post in, then click the big shiny "new post" button
some drunk guy
Aug 3, 2021 06:09 PM
Obmi
Sep 10, 2016 04:40 AM
mct75
Aug 22, 2016 01:24 PM
tyzsdaddy
Jan 16, 2016 09:19 AM
Obmi
Sep 16, 2015 02:13 PM
