Stainless idle screw upgrade
Old Dec 12, 2010 | 09:02 AM
stackedyoda's Avatar
Well a while ago adjusting my idle i broke one of the adjustment screws, and walking around home depot i found the prefect replacement. Here is the broke screw.
So i went to home depot and bought 2 sets of these 10/32x 1in.(only needed one set)
Tools needed are 2.5mm allen wrench, 3mm allen wrench, and 8mm open ended wrench.
It's pretty straight forward, take old out put new in.
It's not a big mod in any way, just thought i'd post it incase anyone else broke a screw and was going to replace with stock set screw, these are much stonger than the stock screws and they look better.
Old Dec 15, 2010 | 07:03 AM
99blackSE's Avatar
One of those screws is for the dashpot is it not? I adjusted the one that contacts the dashpot as I suspected it was messing up the throttle plate relapse. Seemed to help a bit for me.
Old Dec 15, 2010 | 09:10 AM
scope103's Avatar
I'm going to guess that Toyota didn't plan on using an SAE threaded component there.
Fortunately, 10-32 is a little smaller (4.95mm) than the m5x0.8 Toyota used, so you were able to get it in. But since it is smaller than design, you might have an issue with it vibrating loose. Who knows?
My local Ace Hardware has a stack of trays with "unusual" fasteners, including m5x0.8 - 25 button-head stainless. (And lots of other metric sizes) You might be able to wait and see, but since the 32 pitch isn't quite right (0.79mm) it's not doing the threaded part of the throttle arm any good.
Old Dec 15, 2010 | 10:39 AM
spc mike's Avatar
Ya, i would recommend that you get the right metric bolt for that application and i hope you put a little dab of anti-seize on the bolt, because dissimilar metals love to seize and/or corrode together.
Old Dec 15, 2010 | 01:11 PM
99blackSE's Avatar
Originally Posted by razed
neither of the screws are part of the dashpot. not hard to prove by 3rd pic.
dashpot-
rev up normally and throttle closes in about 2 seconds.
rev up normally, pinch vac hose closed and throttle doesn't close.
screw is part of the dashpot, not part of the throttle
Never said it was part of the dashpot though.
Looks like the same screw to me, that is the one that contacts the dashpot.
From 4Crawler:
Dash Pot:
The GREEN CIRCLE shows the dash pot (DP) which is there to slow the closing of the throttle to prevent backfiring. It consists of the round air bellows, a spring loaded plunger, and the air vent line that attaches to the fitting at the base of the bellows. The vent line has a check valve in-line and an air filter to keep dirt out. The check valve lets air into the bellows then the throttle opens and extends the plunger. When the throttle closes, the stop screw contacts the plunger and pushes it in. The check valve closes to slow the air escaping the bellows and thus slow the closing of the throttle.
My understanding is that the only purpose that screw and the dashpot itself serves is to slow the relapse of the throttle blade from open to close, unless I'm missing something?
shisha1999
Aug 14, 2015 01:33 AM
mtc1105
Aug 4, 2015 08:06 PM
Dakotaneu
Jul 27, 2015 12:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
