no fuel in #1 after valve cover gasket replacement! help!!!
Old 12-12-2010, 12:20 PM
erollinc's Avatar
well last night i did the valve cover gaskets on my 90 4runner v6 .... and #1 is getting spark but it doesnt change idle when i unplug it, ive swapped wires and plugs with # 3 to see if i had a bad wire or plug, but no... not to mention my cap , rotor, wires and plugs are damn near brand new.... when i disconnect the other cylinders the idle changes.... is there anything else i can check before i have to rip the ˟˟˟˟ing intake off again and check the wiring the the injectors? im thinking i may have busted a wire to #1 when doing the vc gaskets....
i neeeed the truck running good my tuesday morning any heelp would be greatly appreciated.... actually ill paypal you 10 bucks if you solve my problem lol txt me at 3362557843 if you know somehting ill be in the garage ripping the intake off
Old 12-12-2010, 12:25 PM
erollinc's Avatar
any info on testing fuel injectors would be great as well
Old 12-12-2010, 12:28 PM
Fossilized
Staff
dropzone's Avatar
you can download the FSM in my sig
Old 12-12-2010, 12:49 PM
sam333's Avatar
Run it, and listen for clicking on #1 injector( use a large screwdriver, one end against the injector the other pressed against your ear) no clicking, no operation. You didnt say why you were pulling your plug wires, is it running rough/ missing?
Old 12-12-2010, 01:32 PM
erollinc's Avatar
sorry... its idling on 5 cylinders obviously... and im not getting a reaction from #1 when i pull the wire ... making me think its the injector not firing... i pull any other wire, and the idle changes dramatically
Old 12-12-2010, 01:34 PM
erollinc's Avatar
its idling like a harley in other words
Old 12-12-2010, 02:22 PM
erollinc's Avatar
yep so in the process of pushing the wiring harness out of my way when unbolting the valve covers , i definitely pulled the injector plug straight off #1 ... woops... at least it was obvious... tips for the future, if your truck is old, be slow and careful, that stuff is fragile
Old 12-12-2010, 02:39 PM
Kiroshu's Avatar
This problem only started right after valve cover gasket change? Then you more than likely created a vacuum leak. Get some carb cleaner and spray around the intake runner going to #1 if you have engine performance change(generally idle-up) then your intake plenum gaskets leaking and should have been replaced with valve cover gasket job.... at least its highly reccommended....
Old 12-12-2010, 03:02 PM
rworegon's Avatar
Sounds like you have a broken wire to this injector of the injector is stuck and not firing.
Are you throwing a CEL light that you can query?
Old 12-12-2010, 09:48 PM
erollinc's Avatar
yeah it happened right after the valve cover gasket change... i did put a new intake mani gasket in there... but like i said, i found the problem to be the #1 injector not being plugged in (cause i pulled it off making room to get to the valve cover bolts)
jennygirl
11-17-2015 11:24 AM
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
puddlepirate
06-30-2015 05:08 PM
serenity03k64
06-27-2015 07:59 AM
Quick Reply: no fuel in #1 after valve cover gasket replacement! help!!!
