started the rebuid yesterday
Old Dec 19, 2010 | 04:25 PM
JWillyG's Avatar
86 22re rebuild started.....engnblder kit with the 261 crawler cam. crank goes out monday all parts are in the garage except the 20r head, hopefully Monday.
Old Dec 19, 2010 | 04:35 PM
xxxtreme22r's Avatar
20r head? You got an 86 rig, hope you got an 81-84 motor in there.
Old Dec 19, 2010 | 04:37 PM
slacker's Avatar
yeah .. 20r head wont fit .. or .. well it will .. but you wont find a timing chain to fit ?
Old Dec 19, 2010 | 04:39 PM
His compression is gonna be way low too. Not sure on the timing chain fitting or not though. Oh and I don't think there is a setup to efi the 20r head, but I could be wrong.
Old Dec 19, 2010 | 05:00 PM
JWillyG's Avatar
I am converting to a carb set-up....I thought the 20 head fit the 86?
Old Dec 19, 2010 | 05:12 PM
camo31_10.50's Avatar
no the block height changed in '85.
need a pre 85 22R block. then you're good to go!!!!
without the early block...you're not gonna get it to work.
Old Dec 19, 2010 | 05:48 PM
fit yes, work no.
http://www.toysport.com/technical%20...tech_notes.htm
Old Dec 19, 2010 | 09:17 PM
JWillyG's Avatar
okay so it looks like I will be porting my 22re head, staying away from the 20r head .......I wanted to run a carb set-up but I might just find some injectors and stay with this set-up.....This motor had 310,000miles befor I pulled the engine (still ran good, few rattles a 3-4000 rpm. plus the injectors leaked so start up was rough
Old Dec 19, 2010 | 09:25 PM
James Woods's Avatar
Why would you want to run a carb set up? EFI is just so much more efficient, and isn't that the bonus to buying a post 84 truck?
Old Dec 20, 2010 | 03:50 AM
heh see my sig. Glad my 87 is carb'd more and more every day. EFI might be a little more fuel efficient and slightly better on HP, but it's more efficient for me if anything were to go wrong with the motor to troubleshoot it. And you can't use the extra HP if the truck sits for a week while you try to figure out why the motor isn't getting fuel. lol.
Old Dec 20, 2010 | 07:22 AM
I have had both EFI and carb, and I do not miss pumping the gas to start the car, messing with a choke and being able to go to the mountain without doing any adjustments. To me a carb setup is just a controlled gas leak. But if I were to have a carb setup again, I would swap mine to propane and make it almost as good as EFI. IMO of course
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Colington
Mar 8, 2020 09:51 AM
redneck17
Jul 17, 2015 07:44 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
