PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 [250] 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. O/D Light not working
  2. 3.0 running rich when cold
  3. 95 4Runner Factory Manual
  4. will a mild vibration at 50 damage anything
  5. missing on slight acceleration
  6. 95 4runner disapearing coolant
  7. loud noise on hard left/right turns
  8. 1992 22re a/c question
  9. vibration at 50 mph
  10. How do I remove shift handle with OD
  11. Fan bracket bearing fried!!! :(
  12. Long travel for the rear
  13. Converting EFI to a Carburetor
  14. Moding airfilter, kinda stuck
  15. Help! with engine starting
  16. engnbldr.com head gaskets
  17. Access to the speed sensor on a 93 truck?
  18. PCV/Vaccum Line on Engine?
  19. How does the PCV come out on the 22RE
  20. muffler or no muffler?
  21. Help. 3.0, hissing sound at fire wall, smell of gas, hard to start.
  22. whistling sound from the air intake
  23. Anyway to bypass the knock sensor
  24. Rod end bolts loose?
  25. A/C Condenser Fan Install
  26. Offroad Lighting Location/Mount Photos Wanted
  27. transmission overheating
  28. Best way to get wires into doors in 88 Pickup!
  29. Exedy or Toyota OEM Clutch Replacement
  30. intake manifold vacuum
  31. tourque converter/engine help
  32. Hauling with the 3.0
  33. Downey headers for 3.4L swap q?
  34. Mounting Roof Rack to 1st gen?
  35. Odd cranking issue on 1st gen.!?!?
  36. 86 4Runner Starter Problems
  37. Gear ratio question
  38. 22RE Injectors not getting pulse
  39. radiator
  40. time to part her out
  41. Steering Damper problem
  42. Timing screwed up???
  43. Checking TPS.. where does the vacuum for the throttler go?
  44. 22RE idles rough, any ideas?
  45. bogging out problems
  46. Engine Light On
  47. chech out this 3.0 motor and PICS
  48. please tell me its something other than my headgasket....
  49. lock up valve relay?
  50. 89 22re cam chain question
  51. Parts ID. Rubber hose under oil filter..Coolant??
  52. SAS w/ coils instead of leaf?
  53. Compression numbers bad, need some ideas.
  54. Temp Gauge
  55. 1987 4-runner Idle/running problem
  56. finally put my motor on TDC
  57. 22RE Pistons: Recommendations and Do you get what you pay for???
  58. Replaced shift bushings
  59. Brake woes. 2 new MC's. No pedal press at all.. booster maybe?
  60. Idling Problems
  61. I hear clicking noises on my 92
  62. will engine parts off a 94 yota work on my 89?
  63. straight axle swap
  64. Starting Problem
  65. An idea to get some cold air...
  66. engine mods
  67. 22r power steering pump rebuild
  68. Ticking noise after injector service
  69. torque converter woes....
  70. Got an odd sound
  71. Now I've done it, broken window
  72. AC probs.
  73. 86 4runner interior, engine, transmission restore help
  74. help with trail gear slider install
  75. how do I remove chrome trim around windsheild
  76. Valve adjustment & Idle questions
  77. Removing Panel Under Steering Wheel
  78. Tensioner went bad....Looking for seats.
  79. 22re and nitrous
  80. performance mods
  81. Another brake problem question Master Cylinder?
  82. Finally got pics.
  83. Downey "Long Travel" suspension system, Gen II 4Runners
  84. Gear Grinding under load on 92 5spd
  85. Cold idle too high???
  86. Head Bolts on 89 pu 3.0L
  87. Steering Squeaking
  88. Need Detailed Locations Of Sensors.. Pix would help alot...
  89. Exhaust on a 1993 4runner
  90. TPS resistance #'s
  91. Rear window problem
  92. very low idle and rough with 3.0
  93. Low RPMs when first starting
  94. Idle and throttle issues...
  95. rear wiper and window
  96. My New "Toy"ota
  97. 22R Carb rebuild problem
  98. Power questions?
  99. 4WD Light
  100. 22RTE help --> Intercoolers
  101. Need fuel line part number
  102. Update: OD light flashing starting off in 3rd gear
  103. temp gauge problems
  104. '95 4Runner, power brake failure
  105. 3VZFE rebuild...
  106. What backspacing?
  107. New gear installed
  108. Is this interior the OEM Bluish gray or Gray? pics...
  109. Power dies when depressing back window switch to the up position
  110. Vacuum leak caused a Burnt Valve?
  111. New BudBuilt 1st Gen 4Cyl Belly Pan!
  112. let the mod'in begin...
  113. Starting and Stalling Issue
  114. What's wrong with my timing?
  115. Lowrider, please help!!
  116. Valve Tap
  117. New rig - 86 Turbo Pickup
  118. New rig - 86 Turbo Pickup
  119. 22rtec swap
  120. 22re rebuild
  121. 22re question for all the gurus
  122. 4runner rear seat belts
  123. how is this part removed?? see pic
  124. come on all CHAT ROOM
  125. 88 3.0 speedo cable question
  126. Engine Swap done..um..wont start?
  127. Trouble downshifting from 4th to 3rd
  128. radiator replacement
  129. knock sensor connector
  130. Rebuild or buy new
  131. bolts for the motor mounts
  132. 90 4runner Ceased Clutch
  133. HELP! SM465 Np205 SBChevy in a '94??
  134. pic request....32x11.5 on R15 15x8 rims with 3.25 or 4.5 or 3.75 backspace
  135. broken torsion bar mount
  136. Looking for a source of cheaper leaf springs
  137. Replacing coils and torsion bars
  138. Budget rebuild on an '87 Carbed 22R
  139. Where and which speedometer gear
  140. 93-3vz P/U head gasket leak and recommendations
  141. Need local welder in Pasadena area
  142. Suspension question
  143. weird timing issue
  144. Using 4WD-low without front wheels locked?
  145. 22R injectors not firing or pulsing
  146. Can anybody ID this bumper?
  147. $16 tail gate anti-rattlers
  148. I re-did my intake
  149. Hypoid tranny/xfr case oil, or no?
  150. Can you tell a difference with the new springs and shocks?
  151. Adjustable cam discovered on 22re...
  152. "Sweet" Burning Smell from my '93 3VZE
  153. Starter Question...Maybe?
  154. Just bought an 86' 4runner, need some advice
  155. Horrible mileage ...
  156. My 94 toyota "project"
  157. Up In Flames!!! :(
  158. Advanced timing...can't adjust
  159. transfer case (different gear ratios)
  160. Another 3.0 Header Question
  161. Truck runs rough at cold start..
  162. Brake light barely on, it's dim, barely, I did search
  163. Exhaust backfire on decelleration
  164. HELP cant get engine started after head gasket replacement
  165. fan pulley lock up
  166. BAD INJECTOR 1995 runner
  167. SR5 wheels
  168. rear discs
  169. Engine Replacement
  170. Transmission swap on 3.0
  171. Vibration, '95 4Runner
  172. Does this 4Runner seem like its worth $2000
  173. where did you get your replacement engine online?
  174. Transmission Bolt Patterns
  175. OD light flashing,tranny starting out in 3rd gear!
  176. more 3.4l swap ?
  177. Replacing Driver Side Window
  178. 85 4wd t-case & rear axle to 89 4runner?
  179. What is the cause of Engine Noise
  180. 94 Tacoma 4X4 Drive Shaft,,,Help!!
  181. Hilux/Surf stock brush guard?
  182. check this out - grill swap
  183. I need help with my truck's stance
  184. 94 Hilux fuel filter
  185. 22re harness issues
  186. Door wiring harness 14 pin connector
  187. Where to buy black steel wheels cheapest?
  188. please help, im about to do a swap
  189. Manual Transmission volume
  190. Another timing set thread.....
  191. 3.0 miss when hot
  192. What power difference would I see?
  193. Replacing Passenger Side Vent Register
  194. Driver Side Window Shattered
  195. automatic shifter sloppy, can it be adjusted?
  196. Stumbling since flood
  197. quick 2x4 to 4x4 question (fitment)
  198. 3.0 head gasket in place.. lacks power!
  199. exhaust gasket?
  200. chrome valince?
  201. replacing power steering pump
  202. auto tranny q's
  203. '91 3.0 dying on me, starting to leave stranded HELP
  204. '95 4Runner with ADD, confused about manual hib conversion
  205. 1991 Toyota Ext cab on ebay for rebuild
  206. TPS part number change from toyota/installation troubles...
  207. knock sensor 92 4Runner error 52
  208. Easiest way to convert Std. Cab to Ext. Cab?
  209. No 1st gear 5 speed manual (repair cost)
  210. 4-Runner '90-'95 EGR Headlamp Covers
  211. Tailgate interchange
  212. header leak..maybe?
  213. shocks
  214. Blazer rims
  215. A/C "Idle Up" VSV Operates Without The A/C On?
  216. gas in oil
  217. Alt swaps
  218. 93 4x4 3.0 sr5 oil pan removal
  219. Help changing CV axles on 92 4runner
  220. 2nd gen DIN question
  221. gas tank swap possibilities?
  222. 3.0 oil cooler
  223. '95 4Runner, fuel milage
  224. '95 4Runner FSM vs Alldata
  225. Need Pro Welding help
  226. YotaChat, TAKE A PEEK
  227. OME Springs installed
  228. valve adjustments to my 3.0
  229. '93 4 runner front tranny question
  230. ECU Interchange
  231. did my reseach but still have a few tire q's
  232. How much lift do I have?
  233. 4wd wont engage
  234. Towed a 3k pound boat/trailer over Stevens (WA). Results:
  235. torsions
  236. What T-case in a 86 Turbo?
  237. question about rust repair and prevention
  238. "TPS' sensor
  239. Can you say "Hydro-lock?"
  240. Stalling Out
  241. advice needed on finding a manual 3.4l vehicle for a swap...
  242. head gasket replacement
  243. Replace Turbo Tranny w/ Non-turbo tranny
  244. ID this part and why it is leaking anti-freeze please.
  245. Bent steering relay rod?
  246. good thing the cam didnt break!!!
  247. 3.0 replacement done. 88 4runner
  248. Help, 5 speed stuck in reverse
  249. 22RE Rebuild Options
  250. Master Rebuild Kit for 22RE? Recomendations?
