Blazer rims
Old Aug 22, 2006 | 09:19 AM
CraZyRunner's Avatar
Blazer rims
My friend has a 75 k5 blazer and he wants to sell me his rockccrawler rims with tires does anyone know if the rims will fit my 95 4runner?? The rims are 6 lug on the blazer too but ive heard rumors that the hub hole isnt big enough. anyways thanks for the help.
Old Aug 22, 2006 | 09:25 AM
GSGALLANT's Avatar
Easiest way is to try them on... if your friend lives close by.
Old Aug 22, 2006 | 09:35 AM
gonzo's Avatar
I've got a set of chrome rims that were on a 4x4 chevy on my 95 4Runner.
Old Aug 22, 2006 | 11:10 AM
bob200587's Avatar
yea, it depends. You'll want to try them.
Old Aug 22, 2006 | 12:51 PM
Propayne's Avatar
a chevy six lug SHOULD fit. unless there is something different about the rims.
Old Aug 22, 2006 | 01:07 PM
Bill's Avatar
Chevy Center holes are 4"...or 3.5", where as Toyota requires 4.5"...or 4". Either way, Cehvy Rims are 1/2" smaller center holes. But the 6 bolt pattern is the same.
I am using a set of 15x8 Chevy Rims to mount my 33's. To get them to fit, I needed to grind out the center holes a bit. It took about 20-30min per rim, and it ate a whole 4" disc. But considering I bought the rims for $100, it was a good deal.
Old Aug 22, 2006 | 02:30 PM
Dublin's Avatar
Most chevy 6 bolt rims will fit and most aftermarket chey 6 bolt rims will have a larger center hole. Your biggest problem will probably be the backspacing for the front wheels and caliper clearance and this will depend on the rim design as well. Some have a stepped back spacing and causes more fit difficultys. Do a test fit, turn and rotate the wheels, check your clearances. My rims came off a 99 silverado 15x10's with 4" backspacing.
Old Aug 22, 2006 | 03:43 PM
kyle_22r's Avatar
if they're rock crawler rims they'll probably have the larger "universal" hub cutout and typical 3.75" backspace like most commonly found steelies.
Old Aug 23, 2006 | 09:31 AM
alright thanks guys for the help. my friend live like 5 minutes from my hjouse soo ill test them out.
chukarhunt
Dec 8, 2019 11:39 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
Cycles
Sep 29, 2015 06:37 AM
Bill McBride
Sep 20, 2015 02:51 PM
AkitaDog
Sep 3, 2015 09:01 PM
