Blazer rims
My friend has a 75 k5 blazer and he wants to sell me his rockccrawler rims with tires does anyone know if the rims will fit my 95 4runner?? The rims are 6 lug on the blazer too but ive heard rumors that the hub hole isnt big enough. anyways thanks for the help.
Easiest way is to try them on... if your friend lives close by.
I've got a set of chrome rims that were on a 4x4 chevy on my 95 4Runner.
yea, it depends. You'll want to try them.
a chevy six lug SHOULD fit. unless there is something different about the rims.
Chevy Center holes are 4"...or 3.5", where as Toyota requires 4.5"...or 4". Either way, Cehvy Rims are 1/2" smaller center holes. But the 6 bolt pattern is the same.
I am using a set of 15x8 Chevy Rims to mount my 33's. To get them to fit, I needed to grind out the center holes a bit. It took about 20-30min per rim, and it ate a whole 4" disc. But considering I bought the rims for $100, it was a good deal. |
Most chevy 6 bolt rims will fit and most aftermarket chey 6 bolt rims will have a larger center hole. Your biggest problem will probably be the backspacing for the front wheels and caliper clearance and this will depend on the rim design as well. Some have a stepped back spacing and causes more fit difficultys. Do a test fit, turn and rotate the wheels, check your clearances. My rims came off a 99 silverado 15x10's with 4" backspacing.
if they're rock crawler rims they'll probably have the larger "universal" hub cutout and typical 3.75" backspace like most commonly found steelies.
alright thanks guys for the help. my friend live like 5 minutes from my hjouse soo ill test them out.
