Alt swaps
Old Aug 22, 2006 | 01:31 AM
doc76239's Avatar
Alt swaps
So what are you guys doing to swap out the whimpy stock alternator? Gm swap or just upgrading stock alt?
Old Aug 22, 2006 | 04:10 AM
AH64ID's Avatar
I had mine rebuilt at a shop in Ballard... he found an OEM 100 amp kit, and I love it.. the only issue is the regulator cuts if off at about 650rpm, not sure why....
Old Aug 22, 2006 | 05:10 AM
mastacox's Avatar
An alternator out of a Toyota MR2 with power steering is a pretty easy upgrade, and is 100amp.
Off-Road.com Writeup
Old Aug 22, 2006 | 05:09 PM
doc76239's Avatar
So if I get an 100 amp mr2 alt, it will bolt up? Even though that is for a 4 cylinder? any write ups for that swap?
Old Aug 22, 2006 | 08:26 PM
seanz0rz's Avatar
Guest
yea, kinda curious about this myself, i havent seen a good consencus on running a bigger alt here. im so supprised someone doesnt make an aftermarket one...
Old Aug 22, 2006 | 11:57 PM
TNRabbit's Avatar
AHA! They DO:
http://www.alternatorparts.com/Toyot...lternators.htm
Old Aug 23, 2006 | 05:59 AM
mastacox's Avatar
I gave you the link dude! Check my previous post...
Well, it won't "directly" bolt up, you have to do some minor modifications to the lower adjusting arm and electrical connection. The link I provided shows you the details, the instructions are for a 3.0L V-6 so I don't know about it working with a 22re... The engine that the alternator is "for" is irrelevant, only how much the car requires, the bolt locations and sizes, and the belt used matter. For the MR2's, they have electrically assisted power steering (rather than a belt on the power steering pump it is an electric motor). Because of this they need a pretty big alternator.
It's important to note that you can get one of these alternators "new" from an auto parts store for about $170, and the rest of the modifications cost about $10 if you use your existing alternator adjusting arm; this turns out significantly cheaper than most "bolt-in" aftermarket alternators. I have heard some bad reviews of the Mr. Alternator company that makes bolt-in HO alternators, so be wary of them. Not sure about other brands.
Old Aug 24, 2006 | 05:36 PM
doc76239's Avatar
Yeah i have the 3.0. I was thinkin of the green high output alternators. But they are like 400 bucks. I might just go the mr2 route. To bad no one just makes the bracket. Hell they would make alot of money.
Old Aug 24, 2006 | 06:36 PM
Bumpin' Yota's Avatar
If its a 3vze ya got, you should be idlin at 800rpm... Besides, whats a little more RPM anyhoo? lol
Old Aug 24, 2006 | 06:53 PM
I had a high output alternator from www.hoalternators.com and loved it!!
190amps of powa! Plug and play! Well aside from doing the big three in 1/0ga wire!
Old Aug 24, 2006 | 06:59 PM
ewong's Avatar
At one time I had the "kit" that stuffed in a Wranger Power Products modded GM alternator into a 22RE.
It fit - barely.
I worried all the time about the coolant hose that it rubbed on occasionally.
I ended up going with a modded NipponDenso alt. Bolt in deal. Stock belt size.
You have to upgrade the charge cable tho.
Old Aug 6, 2007 | 10:00 AM
notanymore's Avatar
i tried searching and got 4 threads but will a cs130 gm alternator fit in a 22re?
also i was looking on mr. alternator and they dont have any specifically listed for 87 but will the alternators from 89-91 work? did the plugs change from in these years or something? because its still for the 22re so will it still work?
Old Aug 23, 2007 | 08:29 PM
Dave's D.C. Electric's Avatar
Hi Guys, I'm a new guy here and would like to help you all out with your charging system problems. I own a custom alternator shop in southern california and have extensive off road experience. Would love to work with who ever needs more power. We can get you the power you need at the price you can afford. Feel free to check out my web sight @ davesdcelectric. If you mention that you checked us out from this fourm you will get special priceing. Thanks D.C. Dav
Old Aug 24, 2007 | 05:30 AM
TNRabbit's Avatar
Boyle Future Technology
12325 Locksley Lane, Auburn, CA 95602
phone: (530) 888-6290
Boyle will build it however you ask them for the same price. They provide a "cert" showing the output at various RPM's. Mine was 65 amps at idle & 135 amps max.
Old May 9, 2008 | 09:59 AM
JoKEpLaYeR's Avatar
I've got my truck down for a bunch of work right now, and one of the things on my list is finally getting rid of the factory alternator. I've got an electric fan, lights, and electronics pulling off it and a winch is in my near future....
Has your Boyle alt been treating you well? Any problems? Would you recommend them?
Thanks!
Old May 9, 2008 | 10:39 AM
mt_goat's Avatar
Thanks!
My main complant with them was the packaging they did for the return trip. Send it to them double boxed with real padding (not paper) and use new or near new boxes (they reuse the box you send them). And request that they double box it for the return trip.
Other than the shipping damage (which they fixed at no charge BTW) from the poor packaging mine is doing fine. They come back nice and clean.
Old May 9, 2008 | 10:56 AM
JoKEpLaYeR's Avatar
They aren't that far from me, so I can just drop it off and pick it up. Gives me a reason to get up into the mountains anyway.
How long have you been running yours?
Old May 9, 2008 | 11:01 AM
mt_goat's Avatar
Not very long, less than 2000 miles.
Old May 9, 2008 | 01:00 PM
AZ4ME's Avatar
https://www.yotatech.com/forums/f37/...-mount-139305/
80Truck
Oct 12, 2025 07:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
dfarr67
Jul 30, 2015 07:08 AM
highonpottery
7
Jul 18, 2015 02:48 PM
toyoda8488
Jul 5, 2015 10:18 PM
